Question about Yamaha HTR-5790 Receiver
Yamaha remote control rav238 has error message in window and nothing works
Does rav 246 remote operates a Yamaha htr 5630 receiver?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Jun 30, 2016 | Yamaha Televison & Video
How do I set up new Yamaha RAV360 remote control for my Yamaha HTR6090amp/home theater?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
May 20, 2015 | Yamaha Televison & Video
Were can I find a remote for htr 5790?
The remote for your unit is the RAV-238. You can purchase a replacement here:
http://remotes.com/store/yamaha/rav238.html
Feb 28, 2011 | Yamaha HTR-5790 Receiver
My logitech H628 Harmony remote displays System Error a message
Hi!
Unfortunately, system error one is apparently a hardware issue. It means something about the memory being lost in your Harmony Remote. I had to get a replacement Harmony Remote from Logitech but you would have to see if you are still in your warranty period!!!
I hope you are so you can get a replacement!!! =)
-Kennedy
Nov 28, 2009 | Logitech Harmony 880 LCD Remote Control
Yamaha RAV300 Remote dead, new battery worked then didnt.
Try my instructable on how to repair remotes. http://www.instructables.com/id/Repair-your-remote-controls/
Dec 18, 2008 | Yamaha RAV-300 Remote Control
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Remote device issued disconnect signal on last attempt.
What does the failed message say? Maybe its at the other "end" and not you. If it is nothing you can do except to advise them.
Sep 25, 2007 | Symantec WinFax Pro for PC
How do you re-program the remote to work with the system?
Change the batteries of your yamaha YHT-150 carefully and check that there is proper connection between the two ends of batteries and metal of remote control.
Aug 10, 2007 | Yamaha YHT-150 System
Yamaha HTR-5790 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
