Question about Radio Communications
Manual for TAD M8 need manual to program various receive and transmit frequencies
    Problem Solver:
  • 19 Answers
Http://www.va7alg.ca/what.html has a link to two versions of the programming manual. (Thanks, Google!)
Posted on Jan 22, 2014
3 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: can transmit to other frs radios but cannot
Check the "code" (interference eliminator code) on the FR60 and set it to off or zero. It appears from your description the Cobras do not have "code" turned on. Refer to your user guide to find the instructions for turning off the code. (As of this date we have not found an FR60 manual posted online.)
Best regards.
Posted on Dec 06, 2009
Testimonial: "I set interferance code to zero and it works Thank you Ken"
  • 104 Answers
SOURCE: I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Posted on Sep 14, 2012
Can talk on walkie but cannot hear others
It can be several things. The type of radio, Business band, Ham or Consumer would help. This problem can happen easily. Depending on the brand and model the procedures are a bit different. The transmit frequency is correct since radios can "hear" you. Your receive frequency, or the CODE is different that the transmit frequency and code. These are two different things and must match the transmit information in order to turn your speaker on. To check, if you know how to put your radio into "monitor", you will be able to hear the other radios when they transmit. Then you know to only change the "code". The other unlikely thing is a blown speaker. 90% of the time it is the programming.
Jul 04, 2016 | Radio Communications
Hi I have a vertex vx2100 radio and I need to know if I can use it as a police radio scanner
Yes. The Vertex VX2100 is a VHF radio which can be programmed to frequencies between 134-174 MHz. You would need to program in the frequencies you are wanting to scan as receive only (no transmit) into the 8 channels of the radio. You would need to acquire the frequencies you need, as well as programming equipment, or take the radio to a dealer for programming.
Best regards.
Mar 31, 2014 | Vertex Radio Communications
My uniden hand held radios are transmitting but not receiving why???
Possible programming problem. Your receive frequency may not be set the same as your transmit frequency, or your PL code may be set differently between the radios. Check your programming.
Best regards.
Sep 28, 2013 | Uniden Radio Communications
Radio will not recieve
Hi Andy,
What you have is an amateur radio which requires a license to operate it.
Having said that, I don't know where you got the unit from, but obviously, the unit has had the frequencies deleted, so you cannot operate it until you go to a radio workshop to have the unit re-programmed.
You will only get receive(RX) frequencies programmed, no transmit(TX) frequencies. Sorry, but if you want to operate this unit, you will need to approach the Wireless Institute of Australia(WIA), who are responsible for licensing of radio amateur operators in Australia.
web:www.vk6wia.net for all the info re: licensing requirements.
Cheers,
Peter
Mar 02, 2013 | Yaesu FT-101ZD Owners Manual
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
Hello i have a yaesu ft-2900 it receives just fine but when i transmit it shows error. this radio is brandnew
Hi Gerald,
When you say you used the software to download frequencies, do you mean as in from the internet, or did you have to input frequencies via the software on your PC?
There is a difference, that's the reason I ask.
If, by using the software you manually input the frequencies, then did you input both the output and input frequencies or just output for each channel?
If the latter is true, and you are trying to access another user via a repeater, then that is the error.
Repeaters generally, require both the input frequency = the frequency you transmit on, and the output = the frequency you receive on.
Without both frequency pair, you won't be getting out, and no won can hear you, as you are basically transmitting as a simplex station on a repeater allocatted channel, hence the error message on your display.
The radio you have is used by many amateurs & CB operators, and both group utilise repeaters within their allocated spectrum, excluding 27 meg CB, which is simplex only, but with SSB included.
I hope this answers your query.
Best regards,
Peter
Nov 28, 2011 | Yaesu Radio Communications
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
T5420 unable to transmit or receive. Please help!
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Apr 24, 2009 | Motorola TalkAbout T5000 2-Way Radio
Keewood Protalk 2 way radio xls receives , but doesn't transmit
Hello jf1111,
It could be a low battery. Does the screen go completely blank when you attempt to transmit? Two way radios draw a lot more power when transmitting then when receiving so a low battery might cause the radio to cut out when you press the Push-to-Talk and then the radios might appear to turn back on when you release the PTT. If this behavior persists even after charging the battery then the battery or charger (or both) might be defective.
If the battery isn't the issue then the radio could be programmed incorrectly. Does the problem occur on all channels or just one? The Kenwood ProTalk requires dealer programming with a software kit to set the frequencies for each channel. A channel that is programmed for an out of bounds frequencies would generate an error when the PTT is pressed. You might need to have the programming checked out by your local Kenwood Two-Way radio shop.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 20, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Radio Communications Logo
537 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
