Question about Plumbing
Rohl faucet R77V3 swivel handle frozen - Plumbing
  • 171 Answers
SOURCE: rohl 3810 faucet nut not engaging threads
Hi murphygm,
I'm Harvey the Master Plumber.
Your problem is: You have replaced a leaking Rohl cartridge in your kitchen faucet, but when you
replace the nut holding down the cartridge, the threads of the nut do not
engage. You have tried to push hard down on the cartridge while you turn the nut,
but to no avail.
Assuming you have the correct cartridge, I find it helpfull to take pictures with my cell (easily deleted later) as I disassemble to make sure I'm getting the new one in exactly right because there are only two reasons why the new cartridge won't go all the way in. 1 It's the wrong cartridge or
2 something's not right. Take the new one out and check that everything is correct, it's easy to make a small mistake. That's it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
SOURCE: Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
I have a rohl model r77v3 faucet. is it supposed to rotate on o ring on top of counter? or on the base ring?
All the info is here. Trim Ring, O-ring, Counter.
[PDF]R77V3 (Metal Lever) R77V3LP (Porcelain Lever) - Rohl www.rohlhome.com/pdf/R77V3.pdf
  1. Cached
  2. Similar
R77V3 (Metal Lever). R77V3LP (Porcelain Lever) www.rohlhome.com. Consult your local ROHL showroom for additional information and specifications.
[PDF]ROH8734 Maint Bro_f.qxd - Rohl
https://www.rohlhome.com/pdf/489.pdf
  1. Cached
R77V3 (Metal Lever) www.rohlhome.com ... For complete warranty details and a list of showrooms, go to www.rohlhome.com. ... NOTE: MODELS MAY VARY ...
Rohl R77V3 Single Lever Pull-Out Kitchen Faucet with Metal Lever ...
https://www.ajmadison.com > Sinks & Faucets > Faucets > Pull-Out
  1. Cached
Rating: 3 - ‎3 reviews Brand: Rohl. Series: Country Collection. Model: R77V3. Dimensions. Faucet Height: 8 1/2 Inch. Faucet Reach: 9 Inch. Base Width: 2 3/8 Inch. Cutout Size: 1 3/8 ...
rohl model r77v3 Google Search
Dec 02, 2016 | Rohl Plumbing
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
The handle on my rohl kitchen faucet won't hold its position, how do you adjust or tighten the handle?
under the counter there is a nut that needs tightened . usually need a swivel head faucet wrench to get them tight .
Feb 14, 2015 | Rohl A3608LMPN Single Lever Country...
My rohl A3608 is leaking from the lower swivel on the faucet, how does the faucet above this swivel come off for repairing the leak?
there is a 2mm set screw on the back of the neck. Contact ROHL customer service 800.777.9762 to get replacement o-ring set to repair leak.
Sep 16, 2013 | Rohl Plumbing
Guide to Replacing Cartridge on Rohl R77V3
Look carefully at all the prongs and receiving slots in the body of the faucet into which the cartridge goes to insure proper match.
Mar 03, 2012 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
How do you remove everything to clean it, the faucet wont swivel left to right anymore
Remove the handle and the retaining ring (nut) and pull the spout up and off you may need to replace the o-rings found there and lube the area with a good plumbers lube, reassemble and you will be good to go.
Mar 03, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
How do you take the cap off of a Rohl R3810STN Single handle faucet??
Under the handle is a small cap/cover remove it and the handle set screw in right there.
Feb 13, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
Plumbing Logo
54 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
