Question about Apple iPod touch
Lock my ipod touch says it is disabled what n wont let me do nothing but turn it off
  • trill_teddy_ May 19, 2009
    IT STILL DIDNT WORK. WHICH IS THE HOME KEY
    President:
  • Apple Master
  • 688 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Out your ipod in dfu mode and it will restore
here are the steps
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
Posted on May 19, 2009
  • Steve Brown
    Steve Brown May 19, 2009
    the Home key is on the front of the ipod
    the power is on the top edge.
    try it this way.
    turn your ipod off all the way.(slide to power off)
    open your itunes program
    plug your usb into the computer
    take the ipod end of your usb cable and hold the home key down while you insert the ipod end into your ipod.
    keep holding the home key for approx 27 secs.
    the screen may go blank
    your ipod will mount on itunes in recovery mode and ask to restore.
    restore your ipod.
How to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
Mar 24, 2013 | Apple iPod touch
Ipod touch is disabled and wont let me put in my pass code to unlock it when i get to itunes!
If your iPod touch is locked by a 4-digit passcode, the only way to get past it is to force the unit into restore mode by doing the following:
1. Start iTunes and Plug the iPod touch in to your computer via the sync cable. This could be firewire and/or USB.
2. Hold the sleep/wake button(the button at the top) and the menu button(round button at the bottom) down at the same time. Keep them both pressed until you see the 'restore' screen (an iPod cable and an iTunes disc symbol) on the iPod touch. If the ipod turns off or shows the "Slide to power down", just wait and try again. It takes about 10 seconds. Once the restore screen shows, Release the buttons.
3. Windows should quickly "install driver software" for a few seconds. iTunes should now display the iPod touch, along with a message that the iPod touch is in recovery mode. Click the RESTORE button in iTunes to restore the iPod touch.
Please note that doing this will erase the contents of the iPod touch -- that's how the system is designed to work: a passcode lock is meant to protect the data on the iPod.
Mar 12, 2011 | Apple iPod touch
How to disable a ipod touch
WARNING: DISABLING AN IPOD TOUCH WILL MAKE IT UNUSABLE UNLESS YOU PLUG IT BACK INTO ITUNES AND RESTORE IT.
If you want to know how to disable an iPod touch:
  1. Go to Settings> General > Passcode Lock >Turn Passcode Lock On > type in a passcode
  2. Now, hit the button at the top of your iPod.
  3. Try logging in with the WRONG passcode many times. This will disable the iPod touch.
Jan 29, 2011 | Apple iPod touch
How can i disable my ipod touch?
Do I read your question correctly: you want to disable your iPod?
Or do you want to recover it from being disabled?
For the first one, to disable your iPod:
  1. Turn ON the passcode-lock by going to Settings> General> Passcode Lock> ... and then, tap Turn Passcode On.
  2. Now, to disable it, put your iPod to sleep by pressing the POWER button once. Then wak it up. You will be asked for the passcode before you can use it.
  3. Enter an incorrect passcode several times to disable the device.
Now, if what you want is to recover your device from being disabled, all you need to do is read this tip:
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Jul 18, 2010 | Apple iPod touch
My ipod touch is disabled and wont connect to itunes what do I do
know my ipod show the wire and cd that say's itune what can i do
May 15, 2010 | Apple iPod touch
Please HELPPP MMEE with my ipod touch PLEASEEE
Here I have the easiest solution for you but this will cause a permanent loose of all the data you have on your ipod.
If it is okay with you then follow my instructions here
Dec 19, 2009 | Apple iPod touch
My Ipod touch is disabled Please HELP ME
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes2_bing.gif. Then restore it. Let me know what happened.
Ipod is disabled help please!!!!!!!!!!!!!!!!!!!!!!!!
call phone co they will walk you through step by step unlock
Sep 16, 2009 | Apple iPod touch
My 8GB ipod touch is disabled
You need to put in DFU MODE, and restore your ipod touch.
Easy:
Press The Home Button + power button for 10 seconds. after 10 seconds, press only the Homme button.
And now, connect your ipod touch on itunes and press RESTORE.
Jun 28, 2009 | Apple iPod touch
Apple iPod touch Logo
43 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
