Question about GeneralAire Elite DS-35 Steam Humidifier Elite - 220V, Duct or Remote Mounting, P
Generalaire ds35 humidifier won't drain
Replaced cylinder and drain valve assembly, drain line is clear, when "manual drain" is activated, the cylinder won't drain
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
My generalaire humidifier leak from the bottom , I have check the hose and inside all ok
Did you check the orifice inside the supply water tube? Sometimes the orifice can come loose and allow to much water inside the humidifier.
Feb 06, 2014 | General Filters 1099-LH Humidifier
How to manually activate a humidifier solenoid
If humidifier is running but water valve is not clicking open, check the wire connections. If connection is OK, than unplug the humidifier from 120V outlet, disconnect water valve wires and with multimeter check resistivity on the valve coil. If the coil is burned out/open/no resistance, the coil needs to be replaced.
Nov 12, 2013 | Honeywell HE360A1027 Whole House...
There is no water going into the humidifier, make: Generalaire 1042
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Apr 09, 2011 | General Filters 1042-LH Humidifier
760 aprilaire humidifier does not let water to the filter. I have cleaned and checked the lines in and out of solenoid.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your Aprilaire Humidifier is designed to operate in conjunction with your furnace blower motor. Most installers wire a humidifier to operate when the furnace is calling for heat. To determine if your Aprilaire Humidifier is maintaining proper humidity, turn up the heat temperature 5 degrees above the current room temperature on your thermostat and set your humidifier control to call for humidity. The humidifier control is located on the cold air return duct. To set your humidifier control to call for humidity, turn the control dial to the off position and slowly rotate the dial until you hear a “click” on the control. You should also hear a click at the solenoid valve located on your Aprilaire unit. The humidifier control will have a click point at the current relative humidity level in your home. If the current relative humidity is 45% or the outdoor temperature is above 60F, the control will only operate the humidifier in the test mode.
  1. No click at the solenoid valve indicates an electrical problem. Contact your heating and air conditioning dealer to further check the electrical components of your Aprilaire Humidifier.
  1. The click sound at the solenoid valve indicates there is electricity to the solenoid valve. By turning the dial of your humidifier control to a setting above the “click point” you should see water coming out of the drain line within a few minutes which would indicate your humidifier is working.
  1. If the solenoid valve makes a click sound and there is no water draining from the unit, this would indicate the flow of water is being obstructed.
1. To determine if water flow is being obstructed, turn the dial of your humidifier control to the off position. The first location you would want to check for an obstruction would be at the saddle valve located on the water line supplying water to the humidifier. When checking the saddle valve, you want to make sure it is completely open. This can be done by turning the valve all the way to the left. If anything is clogged, it can be dislodged by turning the saddle valve all the way to the right and back to the left. Once this is done, turn the humidifier control dial above the click point and you should see water coming out the drain line.
If water is still not coming out of the drain, check the orifice and in-line strainer to make sure they are not clogged. The orifice is located in the tube on the discharge side of the solenoid valve and the in-line strainer is located on the inlet side of the solenoid valve. You may clear the orifice by inserting a needle through the small opening. Clean the strainer by running it under warm water to dislodge deposits or replace. After clearing and re-installing the orifice and strainer (be sure to double wrench all water connections), turn the humidifier control dial above the click point and you should see water coming out the drain line.
Mar 10, 2010 | Aprilaire Humidifiers
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Water is getting to my solenoid valve and the valve is activated as it is warm to the touch. No water on the back side of the valve to the humidifier. It is on sometimes and other times is doesn't work....
Valves do go bad, but I had the same issue and it was the inlet orifice that was plugged.
To fix: Turn off the water supply. Disconnect the water inlet line to the solenoid. The water inlet line connect to ~ 1" long piece that goes into the solenoid. Unscrew the water inlet piece and remove it from the solenoid. Check it for water flow - water should slowly drip out the small orifice at the soleniod side. There is a pin-hole sized orifice on the solenoid side and it doesn't take much to plug it. There is also a narrow cone-shaped filter inside the inlet piece. You can use tweezers to remove the filter and & use a safety pin or sewing needle to clear the orifice. Check the filter, clean it if necessary, and reinstall the filter. Now check for water flow thru the part before reinstalling. Reconnect the water inlet line and turn on the water supply. Turn your humidistat to trigger the humidifier. You should see water flowing through the drain tube.
Dec 13, 2009 | Honeywell HE220A1019 Whole House...
No water flow in humidifier
clearly your water pump is broken. or you solonoid
Nov 11, 2009 | Aprilaire 600 Humidifier
GeneralAire Elite DS-35 Steam Humidifier Elite - 220V, Duct or Remote Mounting, P Logo
46 people viewed this question
Top GeneralAire Humidifiers Experts
Paul Carew
Dennis
Are you a GeneralAire Humidifier Expert? Answer questions, earn points and help others
