Question about Breville SHM2 Stand Mixer
Parts require pair of drive wheels/cogs for mixer
Both nylon drive wheels need to be replaced asap how do I acquire them
How to replace fibre cog on Hobart ae 200 mixer
probably find that there is a bearing on the end of a shaft/s that are in the cover , so a small amount of persuasion using a pry lever will get the cover free of the bearings
Sep 07, 2017 | Food Mixers
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
I have a A701A mixer and require a new planet gear which is made in nylon. This gear drives the mixer attachments. Where can I get this gear?
Please post your query to the following link and send details to the customer care/contacts link:
www.kenwoodworld.com/en-my
www.thefind.com/appliances/???browse-kenwood-mixer
Sep 29, 2010 | Kenwood KM800 Major Classic Stand Mixer
The problem's in a Kenwood Chef food mixer. Model is Chef A703C which I imagine will date back to the 1980's or 90's Problem # 1) The bearing on the top of motor is sloppy. It howls when operating the...
Try Ebay for parts, and the links below, they sell parts and service machines.
http://www.kenwoodchefusedmixersandspares.co.uk/
http://kenwoodchefrestore.co.uk/Service.htm
Mar 11, 2010 | Kenwood KM300 Chef Stand Mixer
The mixer will not start. Power gets to the unit and the blade does turn manually.
Hi - I assume you mean to say that the motor turns on, runs in all speeds but no power is being transferred to the planetary head and beaters?
If this was preceeded by some intermittent run conditions like occasionally skipping beaters and some louder than normal or different run noise then it's likely that the nylon Worm Gear has lost teeth and is no longer making contact with the motor gear. It is part of an assembly which is directly coupled to the motor. Disassembly is required to get at this part and some mechanical skill to replace it. If the mixer's a few years old and/or gets a lot of use, the gear grease should be replaced too. For the gears and other parts, including the grease - check out http://www.goodmans.net/get_dept_933.htm They seem to have just about every part needed and fair pricing. Appliance Parts Pros is another source of parts and diagrams. Warning - mixer disassembly is a medium complexity task and could ruin your day...
DZII
Jan 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Grain mill stops turning
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
May 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My west bend hand mixer (model # 41015) blades do not turn
your unit is not worth repairing parts will be very hard to get this unit is usally a throw away unit
Dec 10, 2008 | West Bend 41036 Mixer
Mixer stuck
It sounds like you burnt the motor out or shorted the speed control.
Dec 24, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Gearbox input toothed cog
I don´t think you can get a new one, you have to replace the gearbox on the machine.
Dec 02, 2007 | Kenwood KM800 Major Classic Stand Mixer
Breville SHM2 Stand Mixer Logo
41 people viewed this question
Top Breville Food Mixers Experts
jwinter716
Level 1 Expert
Bill Boyd
Tom Chichester
Are you a Breville Food Mixer Expert? Answer questions, earn points and help others
