Question about Refrigerators
KitchenAid ksss48qmb01- divider between the two compartments is very HOT
  • onewideworld May 19, 2009
    No Solutions yet....................
  • onewideworld May 20, 2009
    WHAT A SCAM!!!!!!!!!!!!!!!!!! NO HELP UNLESS YOU PAY. THANKS FOR NOTHING!!!!!!!!!!!!!!!!!!!!
    Problem Solver:
  • 5 Answers
Generally this problem is caused by the evaporator fan not running, check the evaporator fan motor for blockage and or failure.
Posted on May 20, 2009
Condenser fan problem on Kitchenaide Refrigerator - kscs23inss01
What you are going to find is this... Your COILS under the Plastic are Condensating and FREEZING and then this is what is causing the On /Off of the Temp. You have to DEFROST the COILS (Under the Plastic) and remove ALL the ice and Moisture. Once you get this problem resolved, it will work perfectly. This problem was caused by the Condenser Coils being Dirty and and the Switch on Top, Under the Plastic from being unable to work properly. This is a time consuming issue but easy to do. DO NOT SCRAP or BREAK the ICE after you take the Plastic off, use a hair dryer or Hot Water and make sure the Drain Tube is completely cleaned...
Mar 03, 2014 | KitchenAid Refrigerators
The inside frame/black in color that divides the freezer and refrig is very very hot
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Apr 28, 2011 | KitchenAid Refrigerators
Hi woke up this morning and the divider between the freezer and refridge compartments was very hot. Kitchenaid model ksbp25fkss. opened back panel, and compressor was also very hot. also seemed to be...
if it is making a lot of noise then your compressor is going out, if it is full of dirt dust or debree vacume it, or if you have a air compressor, then blow it out, but unplug your fridge to let the compressor cool down, if it is cold outside and you can wheel it there with no problem then you can clean it . you might have a freon leak or a stuck valve let it get cooled off and try again
Dec 12, 2010 | KitchenAid KSBP25FKSS Side by Side...
Divider between two compartments is hot model 106.59599990 side by side refrigerator
It is supposed to be hot. Approximately 110 degrees.
It prevents condensation between the doors.
The hot gas refrigerant line is routed through the conduit in between the doors.
It is OK.
Sep 06, 2010 | Refrigerators
The divider between the two compartments of our model106.51564103 is very hot.
This is caused by the condenser running hot due to being dirty or a fan failure, see the link below for instructions and details I put together for this issue. Let me know if it was helpful.
Hot Divider
Jun 02, 2010 | Kenmore Refrigerators
KitchenAid Dishwasher Rinse Aid Clogged w/ Detergent
have you tried distilled vinagar? this may work for you.
Jul 29, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Divider between doors has extreme heat for side-by-side model
there are 2 pipes running there to reduce the temp in the compressor its normal
Jun 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
