Question about Dryers
Motor hums when it tries to restart - Dryers
  • Dryers Master
  • 2,341 Answers
Next time send the model number,you either have a bad motor or something is stuck in the blower wheel,try this,open the door,push in the door switch and with your other hand spin the drum as someone else pushes in the start button,sometimes this helps the motor to run but you do have a bad motor.if the dryer hasn't been taken apart and cleaned lint builds up on the motor and the oil in the motor either leaks out or burns away from the heat,you might see lint stuck on the back of the drum and oil under the lint or on the side wall of the dryer closest to the motor you'll see lint stuck on the wall with oil under the lint.
Posted on Jan 19, 2014
Compressor hums when trying to restart after tank is full
It may need more power to it available at start up. try plugging it directly on the wall without extension cord. check the amps of the motor and use a circuit capable of delivering the power to the compressor motor
Mar 14, 2015 | Air Tools & Compressors
Dryer motor hums ant wont start
Thais probably the motor but it might be something in the blower housing. Their are lots of movies on youtube that will show you how to do it. Now here is my home movie of a dryer like yours:
Sep 08, 2012 | KitchenAid Dryers
Motor hums but blade will not rotate
Sounds like a start capacitor.
Feb 19, 2012 | Saws
My furnace was making noise then shut down. I turned it off tried to restart. It just has a small humming noise now
sounds like possibly the indoor fan motor has gone bad....try turning your thermostat to "fan on" and check for air flow. if no air flow the motor will have to be replaced
Oct 21, 2010 | Heating & Cooling
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Problem with installed dryer replacement motor
try blow out motor with compressed air not vacuum thumbs up
Aug 12, 2009 | Kenmore 800 7982 Dryer
Dryer just used it and won't restart...just hums can you help?
Hi. thanks for your question. If the dryer just hums when you push the start button, the problem could be the motor. To check lift up the top. remove the front , check the motor, ,
Jan 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
8 year old Whirlpool gas dryer will not run - it just hums when put on any setting. Is this a motor problem or the belt?
it sounds like the motor....generally before the motor dies the motor will become louder and louder, and when its hot and you try to restart it it will make a loud hum as it tries to turn
Dec 31, 2008 | Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
