Question about Sansui Televison & Video
Sansui 24 in. Flat screen and hooking up a Xbox
Trying to hook up my sons xbox to his new 24 in. Sansui Combo TV and the xbox doesn't show in color, however; the tv has perfect color.
  • Sansui Master
  • 722 Answers
Please open the menu go to color systems and change the setting which brings the colors.
Posted on Dec 30, 2013
SOURCE: What is the factory reset code for the dell w3201c
Code is 3355
If that fails, try this
* Press and hold the Input Source button - on the TV (not on the remote); continue to hold it until the last step
* Press and release the Power button
* The TV turns off
* The TV turns on
* Wait 10 seconds
* A message appears saying the TV has been reset
* Release the Input Source button
Posted on Dec 23, 2010
  • 4102 Answers
SOURCE: Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Posted on Feb 29, 2008
appman67
  • 33 Answers
SOURCE: how to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
Posted on May 03, 2009
rlamkin
  • 44 Answers
SOURCE: Don't know where to hook cable wire into my W4207-Flat Screen
Nice tv - but its a monitor, so there will NOT be a RG6 cable connection on the set. you have to provide a tuner to get signals OR use a cable box, sat box, etc.
Posted on May 05, 2009
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
We have xbox360 it's hooked up to sansui sledvd244 how do i get split screen so there can 2 players please help
Minecraft Xbox 360 is a multiplayer game by default. Players can join online or locally via connected controllers. Split screen is a way to play multiplayer on the same console. To play split screen, the Xbox must be outputting a resolution of 720p or higher.
you must have an HD TV for split screen. Connect Xbox to tv with an HDMI cable. Start mine craft when you've logged on with your first controller enter your desired world then pause the game. Turn on and sync your other controllers if they haven't been connected before.Log in those controllers and press Resume Game.
  • Your television screen should be split into two or four parts depending on how many controllers are connected.
Dec 06, 2014 | Sansui Televison & Video
Xbox 360
Match the colors of the cables with the cords and connect...
Mar 16, 2014 | Curtis LCD3235 32" 720p LCD TV LCD3235A /...
I'm trying to get my Xbox hooked up to my old quasar color tv. Idk which channel the game setting is in, I don't have the remote
if you've tried video 2 then you should hook a vcr to the tv then put the video and sound cords in the vcr. turn it on turn the tv to channel 3 and hit the vcr/tv button then the game will show up on your quaser color tv
Dec 26, 2012 | Televison & Video
When I hook up my xbox 360 to a floor model flat screen that is probably 7 or 8 years old, there is sound but no picture. When we hook it up to our newer model flat screen everything works fine. Can you...
Are you trying to use HD? Component cables or HDMI? Component cables limit you to 720p. It's possible that your old TV doesn't support 720p or there is something wrong with the jacks. What sort of connections do you have?
Sep 03, 2010 | Microsoft Xbox 360 Console
I am trying for the frist time to hook up my son xbox360! what do i need to do. The hook up is are pluged in tight & my internet is on as you can see" what do i do?
If you are trying to connect to xbox live you should plug in your ethernet cable to the back and than turn on the xbox 360 and select xbox live..
If you are trying to "hook" recieve visuals plug all the cords the xbox came with into the right places and plug the opposite ends correctly into the tv than make sure your cables are on the settings tv not hdtv than find the input your tv must be on to ie: input1 or source
Apr 23, 2010 | Microsoft Xbox Console
Hooking up xbox 360 to tv
put it on hd. the big plugin that say tv or hvd
Feb 07, 2009 | Toshiba 32HL95 32 in. LCD TV/HD Combo
No picture only sound with the xbox system
This definately means Audio/Video cables were hooked up incorrectly.... New televisions are getting more and more complicated..... . make sure that the switch on the cable is set for HDTV... experiment a little... have the tv, and the xbox both on while you are doing this,,, while having someone watch the tv to check everything out. I had this same problem with figuring the hook-up on a newer tv. On my tv... The channel i play games on is : Composite.... on the back of my tv... where i can hook the audio/video cables up to... it also has a little white border around a certain set of plug-ins which says Composite right above it... all of the cables plug in to that one, except the yellow one.... If this does not work, just let me know and i will figure out a different solution... but im 99% sure this will work. Let me know if there are any other questions. Please rate this answer :)
Dec 29, 2008 | Microsoft Xbox 360 Console
Vizio L37
Sounds like a bad av connection on the main board. i would try to connect the xbox via an alternate av connection or hdmi to verify problem. contact vizio support and describe your problem. they have had trouble with this main board. some of their parts have lifetime warranties and the service call is free. changing out the main board is a pretty simple process, about an hour or less. hope this helps.
Sep 28, 2008 | Vizio L37 Television
Xbox
Do you have it hooked up straight to your tv or is it hooked into a System Selector? Your cables might be going bad, or what ever you have cables plugged into is going bad.
Sep 26, 2007 | Microsoft Xbox 360 Console
No color on tv when xbox on
Try hooking the xbox up to another tv to see if you get color. If you do it isn't your xbox. If you dont then it's your video cables going bad. Hook a dvd player into the same spot you had the 360 in on your LCD see if you get color. If you dont then its your TV, if you do then it's your xbox video cables going bad.
Aug 25, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
120 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
