Question about Tablets & eReaders
Kocaso 2600mAh power bank isn't charging my iphone
Kocaso model m9200 will not charge. no power light
Test your charger and the cable. Might use electronic tester. If you don't have you should seek help fron technical service. I don't know if battery is servicable, If charger is ok, probably the problem is the battery.
http://www.kocaso.com/manuals/M9200/M9200_User_Manual.pdf.pdf
Jul 17, 2015 | Tablets & eReaders
Why mmy kocaso tab woont turn on
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
Touch screen is not working properly
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
This should reset the calibrations to default.
http://www.kocaso.com/troubleshooting.html
Mar 08, 2014 | Kocaso M766 Dual Core 1.5Ghz Dual Camera...
Can i charge my kocaso tablet wirelessly
No, the only to charge it is via the USB socket.
Feb 05, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Kocaso m1068 will not power on
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 28, 2014 | Kocaso M1060W Tablet
Kocaso m750
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. Support Troubleshooting Guide
Jan 25, 2014 | Kocaso Tablets & eReaders
Kocaso M736 is stuck on the Android screen
Jan 23, 2014 | Kocaso M730w 12ghz 4gb 7 Capacitive...
My Kocaso M1062 will not take a charge and says connect charger.
The power Cell (Battery) no longer accepts a charge. The exception is if the AC/DC charging adapter has failed. See if you have a similar power charger around the house. Look for the same type of male pin and proper DC or AC Voltage plus Amps as listed on the current Tablet Charger. Never leave chargers in the electrical outlet alone as they can be damaged by surge power. Try another charger and if that fails also, the power cell in the tablet needs replacing.
Dec 19, 2013 | Kocaso Tablets & eReaders
Android tablet m750b KOCASO problems loading
Turn it off completely. Either by reset or shutdown.
Leave it off.
plug in charger and leave it alone for 4 hours.
Power it back on.
Jun 03, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Kocaso M750B Android 4.0 OS 7" Capacitive Touch Tablet PC came with wrong power cord
I don't have a fix, but I feel a scam since I just got mine today from No More Rack & mine cord doesn't fit either.
Apr 02, 2013 | Kocaso M750B Android 4.0 OS 7" Capacitive...
Tablets & eReaders Logo
74 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
