Question about Samsung 6350 Series UN50F6350 50" LED Smart TV 1920x1080, 240 Hz, HDTV
How to put UN50F6350 LED LCD TV on the base - Samsung 6350 Series UN50F6350 50" LED Smart TV 1920x1080, 240 Hz, HDTV
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
HOW FAR CAN THE PEDESTAL STAND 'SWIVEL'? I CAN GET ABOUT 15 DEGREES EITHER WAY - IS THIS THE LIMIT OR CAN I ADJUST TO INCREASEDEGREE OF 'SWIVEL'?
I believe this is the limit, physically altering the engineered base for this television may put it in danger of falling or breaking. It's a 40 inch LED TV and really not that heavy, perhaps you could look for a lazy Suzann type of base that you could put beneath the TV to give you more extreme swivel capability.
Apr 17, 2015 | Samsung LE40R73BD 40 in. HD-Ready LCD...
LG LED tv no picture but do have sounds,
the LCD screen has a light source (like a monitor). It can be an lamp (like a projector TV), a mercury tube (like a monitor) or a LED-based lamp (so-called LED TVs have that, not to be mistaken for OLED TVs, where each pixel is a LED). I don't believe this model is an OLED. It could be one of the others, most likely a mercury lamp that lays at one side of the monitor and illuminates the screen.
You could shile a flashlight to the screen (from close distance) while the TV is powered on and see if any image is being formed on the LCD. If it does, the lamp is burned out and needs replacing. If no ghostly image is seen, then it could be the video processor and then it's a bigger problem.
Apr 09, 2014 | LG 42LC3R 42 in. LCD TV
Is sony klv32-a400a is a led or lcd tv
An LED TV is still an LCD TV, just with LED backlighting. That model is an LCD TV. The difference is in the backlight. Both LED and LCD TVs use an LCD screen. LED TVs have LED backlighting of the LCD screen, which saves energy.
Nov 04, 2013 | Sony KLV32S400A 32 in. LCD TV
What is an Samsung UN40D6500 LCD TV? LCD TV Liquid Crystal Display, which stands out from the bulb or CCFL Cold Cathode Fluorescent Lamp, which is a thin tube like a drinking straw. By horizontal long as...
Hello
What is this? Are you trying to take a class to everyone to thie world, how the LCD TV works? I think you be a student, not a professional. If you wer a professional, you may won't dare to post this as a problem. OK.
Feb 11, 2012 | Computers & Internet
Please help me for may led monitor asus vh197d how to remove the base to put in to a wall tns
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Mar 30, 2011 | ASUS VH197D LCD TV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do I remove the base so I can put the TV on the wall
Most TV's have the base fitted with a lock that clicks on the main frame of the LCD TV. So all you need is to keep the LCD on a soft surface like a mattress and check to see the lock linked to the main frame. Push to remove the link locks and remove the base stand.
Jan 12, 2011 | Daewoo DSL26T2WCD 26 in LCD TV
Samsung 6350 Series UN50F6350 50" LED Smart TV 1920x1080, 240 Hz, HDTV Logo
19 people viewed this question
Jerry Greenberg
Jerry Greenberg
