Question about Canon FAXPHONE L170 Plain Paper Laser
Need to key number twice to send a fax
Every time I wish to send a fax, the machine will request me to confirm the fax number again after I press the "start" button, although I've key in the fax number - that makes me need to key the same number twice. How can I remove this "confirmation" setting?
  • 29 Answers
Its something that can't be changed... its to prevent faxing private and protected medical info or legal info to wrong #...
Posted on Dec 30, 2013
SOURCE: Confirmation pages
press function
press dataregistration
press set
use scroller up and down to select the function that you want to do, there's a lot of function, like user setting, report setting vvvvv.
select user settings, then scroll up or down
select activitiy report, then set it auto print off
will help you, play around with it.
Posted on Dec 14, 2007
SOURCE: Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Posted on Feb 23, 2008
  • 4 Answers
SOURCE: How to have fax confirmation sheet print
open both one-touch speed dialing panels--press DATA REGISTRATION >set> press search buttons to display REPORT SETTING >set> search to OUTPUT YES (This will print a report with every transmission, next option will give you the option of whether to print the first page of the document (yes) to remind you of what it contains)
Posted on Mar 23, 2009
  • 1126 Answers
SOURCE: How do I get a confirmation page of a sent fax on Canon SuperG3?
Tx (confirmation) Report needs to be enabled before sending the fax. Super G3 is an industry standard, not a model number. What model of Canon facsimile do you have? I have most User Guides downloaded...so I should be able to provide directions on enabling Tx Report. Let me know.
Posted on Aug 17, 2009
iservice
  • 318 Answers
SOURCE: Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Posted on Sep 11, 2009
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
How to send a fax
1)place the document or paper which you want to send in the fax machine feeder facing the direction the machine specifies
2)Now use the number pad in the machine and type the number to whom you need to send the letter
3)once you have finished entering the number press the send key thats is in the number pad
4)once your page is send successfully you will get a confirmation print in your machine
I hope this will help you If it does do rate this answer
Thanks for using fixya
regards
Lalith
Mar 15, 2011 | Office Equipment & Supplies
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
I NEED TO RE-PROGRAM PRESET NUMBERS, BUT DON'T HAVE MANUAL FOR CANON L350 FAX MACHINE?
Open panel cover Press DATA REGISTRATION Press V to display 2. TEL REGISTRATION Press SET twice Press V (if necessary) until an empty space appears Press SET twice Enter Fax number Press SET twice Enter name using number keys (e.g. 2 = A,B,C like a mobile phone) Press > to enter next letter Press SPACE to enter a space Press * to enter a numeric Press SET To continue press DATA REGISTRATION Repeat steps 5 to 10 To end press STOP
Feb 09, 2010 | Canon FAX-L350 Plain Paper Laser
I WANT TO SEND THE SAME FAX TO SEVERAL NUMBERS
You are wanting to use the Broadcast feature of your fax machine. According to page 65 of the users manual, you load the documents, press Broadcast, and enter the receiving numbers by using the rapid keys, speed dial keys, group keys, or individual telephone numbers (maximum of 20) pressing Start/Enter between each of the entries (except for the rapid keys and speed dial keys). Set your contrast and resolution (if desired) then press Start/Enter twice to being.
Feb 01, 2010 | Sharp FO-4400 Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
How do I change the company name that's displayed on the top of the page of a fax??? It's a Canon Faxphone B740.
On the right hand key pad
1). Press Function
2). Press 01 (data registration
3). Press set twice
Display the tel number, change if that is wrong
4). Press set twice again
Enter the company name (unit name)
Use the numeric keys-max 24 characters
if you have otehr problem, please to to the following link and download the users manual.
http://www.usa.canon.com/cpr/pdf/Manuals/B740CanonUserManual3-13.pdf
May 22, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP Photosmart C6180 All-in One Series prints out a Fax Log after each Fax sent, How do I change the setting so that it prints a Fax Log only on request
Press the Fax Menu button twice to get to the Fax Menu to select or change Fax Options. I didn't see Fax Log in the manual, but I think they refer to it as a Fax Confirmation.
The only reference I saw in the manual was this:
"Note If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes."
Oct 20, 2008 | HP Office Equipment & Supplies
Canon FAXPHONE L170 Plain Paper Laser Logo
43 people viewed this question
old marine
old marine
