Question about Samsung LN-T4071F 40 in. LCD HDTV
Can't get full HD image to fit within the screen. Std Def Widescreen works fine. When I try using HD (720p or 1080i), the image doesn't fit in the screen (no black bars - opposite problem. Image fi
Input is AT&T U-verse.
    Master:
  • Samsung Master
  • 687 Answers
You need to check your TV & Uverse box settings
Posted on Jan 03, 2015
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: Using Widescreen setting on Samsung LN-T4671F 46" LCD TV.
nice just helped me....cablevision also
Posted on Mar 15, 2008
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
  • 89 Answers
SOURCE: HD image doesn't fit in the screen.
Contact your cable operator and get the settings on Set top box adjusted. This will help you fit the image
Posted on Jan 01, 2014
HOW TO GET FULL SCREEN ON KONKA TV
Change the aspect settings to fit your TV:
  1. Press MENU on your remote control.
  2. Use the down arrow button to highlight Settings, press OK.
  3. Use the down arrow button to highlight Television, press OK.
  4. Select Screen Aspect ratio and high definition, press OK.
  5. Use the arrow buttons to select 4:3 standard definition, widescreen standard definition, 720p on high-definition screens, or 1080i on high-definition screens.
  6. Press OK.
Apr 24, 2017 | Miscellaneous
Tip
HDTV cable hookup for HD component video
High Def (720p, 1080i) requires either HDMI or component video cable connections. This image shows how to connect using component video/audio. The RCA cables are green, blue, red for video and white and red for audio. Select the HDTV input using the TV remote.<br /><br /><img src="alexander404.jpg" /><br />
on Mar 06, 2011 | Televison & Video
Jan 01, 2014 | Samsung LN-T4071F 40 in. LCD HDTV
How can you tell if a tv is High Def or not?
If a TV is Widescreen Shape, it is usually going to be HD. It's just a matter of HOW HD. 1080i, 720p, or 1080P. Google is always useful ;-)
May 14, 2010 | Televison & Video
TV set always starts up indicating 420p. How do I get it to 1080?I have Bell expressvu HD
is your cable or sat in HD(720p, 1080i, 1080p) over the air broadcast in the usa is in digital so it should start at the highest res available in your area
next are you using HDMI or composite for your cable or sat going into your tv if not your not going to get higher than 420p because A/V and S-video do NOT support HD
check your cable/sat box is it HD(high def) or SD(standard def) if SD going through cattv/attn in your only going to get 420p
now for changing the resolution its automatic it goes to the highest setting on its own
you can control the resolution through your cable/sat box, blue ray/hddvd player and other HD devices connected to the tv through the options menus of those devices BUT only when connected through
HDMI(supports 720p, 1080i, 1080p)
composite(supports 420p, 420i, 720p)
A/v and S-video(supports 420p)
cat tv/attn in(supports 420p, 720p, 1080i, 1080p) only supports what the tuner will do
i=50hz
p=60hz
Feb 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Screen size problem on 720p
Best to contact sony, local game repair shop.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Full hd capable, but only functioning in 480. how do i set my monitor to 1080?
i would have to know what type of connection you are using. usually in most hd monitors, the vga plug will only show up to 480i/p and some will show 1080i. DVI will only show 480i/720p/1080i and if it has an HDMI you can get 480i/480p/720i/720p/1080i/1080p. you will also have to set you resolution of your video card to match.
Sep 18, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
How to make a flt screen in to full screen picture
On your remote there should be a ZOOM button that will strech the screen to full screen it may not be a desirable look but most formats today for HD tv is widescreen format also in your menu system you can change this as well. thanks for using fixya please click the accept button.
Aug 18, 2009 | Insignia IS-LCDTV32 32 in. Television
Screen Issue when HD Satellite Receiver is set to 1080i
these tv's are absolute garbage. Ours does the same thing with hi def.
never again for a samsung
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Sep 20, 2007 | Samsung TXN3071WHF 30" TV
Samsung LN-T4071F 40 in. LCD HDTV Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
