Question about Whirlpool Duet GHW9150P Front Load Washer
Washer door wont latch ghw9200lw duet
The washer got out of balance pretty bad my son ran in and pulled the door open while it was shaking violently
  • ace_bridwell May 19, 2009
    I REPLACED THE DOOR LATCH TODAY, AND IT STILL WONT LATCH
  • 5,911 Answers
Pulling the door open during the wash cycle meant that it was pulled open with the latch in the locked position. The door cannot be opened in this manner while it is operating. If the door now does not latch, it has probably been damaged and needs to be replaced. The following link explains how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be purchased on line at appliancepartpros.com. Just type in your model number and look under Section 5, for item number 7. The door latch is listed as part number AP3837611.
If you have questions, please let me know. I hope this helps you.
Posted on May 19, 2009
  • Jeff Rockwell
    Jeff Rockwell May 19, 2009
    Thanks for Trying? You never mentioned anything about replacing the latch in your question. Would have been nice to have this information before I researched all that information for you. Did you check the latch on the door itself, or the door latch mechanism inside the washer? Did you very the wiring was correct when you reconnected all the electrical connections? Are you receiving any fault codes?
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Whirlpool duet ghw9200lw front load washer will not start cycle
Check the door interlock on the washing machine. If it's faulty, the machine won't start its cycle. This page will give you an idea of what interlocks look like.
Door Interlocks
Feb 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
unplug the washer,remove the lower panel,put your hand under the front panel on right side and pull a level on the door latch and pull the door open.
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door won't close after opening during cycle
door latch needs replacement.its cracked.so the door is not closing.as you said it was moving vigoursly.that means its the motor problem too.that was blocked so it was moving the washer.
May 06, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
679 people viewed this question
Dan Webster
Dan Webster
Sal De
