Question about 2004 Mustang Factory Wiring Diagrams
I need a diagram showing how to install diaphragm on 3406b catipillar brakesaver
1987 Peterbilt 359, 3406B Cat, No brake lights, relay? Wiring?
Hello you might want to check the fuse most likely its in the wiring you may have a short some where you might want to check your wiring starting from the Rear Oh yes you may need a new light bulb for your brakes If all fails take it to a shop
Feb 22, 2017 | Cars & Trucks
Tip
Diagram-Type Faucets
DIAPHRAGM-TYPE FAUCETS
  • The diaphragm faucet is washerless but is similar to washer-type faucets. A rubber diaphragm between the stem and seat creates a straight-down, frictionless close. As with washer-type faucets, diaphragm faucets have two handles.
  • Remove the stem by following the steps outlined for washer-type faucets. Instead of a washer on the end of the stem, you'll find a swiveling disc. If the rubber diaphragm doesn't come out with the stem, it is still inside the faucet.
  • If the diaphragm didn't come out with the stem, use pliers to peel it from inside the faucet and pull it out. Install a new diaphragm around the swiveling disc, then replace the stem in the faucet.
  • If the faucet is leaking around the stem, replace the stem's O-ring before reinstalling the stem.
on Jan 16, 2010 | Plumbing
1987 Peterbilt 359, 3406B Cat, need a wiring diagram, more specifically the diagram for the fuse/relay box thats on the passender side of the dash console.
WHAT IS WRONG WITH THIS UNIT, I CAN DO SOME RESEARCH SEE IF I CAN COME UP WITH A DIAGRAM, EVERYTHING BEFORE 2000 IS IN BOOKS.
Looking for free wiring schmatic for truck pretaining to c 12 catipillar engine ecm
Good luck.. I searched for a few years. Finally started buying them. Since you have caterpillar engine/tractor, I would suggest you go to the manufacturer. Yeah, it will cost you, but well worth it. No one on this site will give you what you need. I work on cars. But I could do your's also, would just take a it more time without pin outs and diagrams.
Nov 28, 2015 | Cars & Trucks
How much oil does a catipillar 3026 take and what kind of diesel oil do I use
I know the oil, it is either of the 2, Caterpillar Diesel Engine Oil 10W30 or 15W40. I know some take up to 124 gal. some less. Call you closet Catipillar Dealer.
May 17, 2014 | Cars & Trucks
I'm replacing the diaphagm on my ce40filter. Does it need gasket cement
No, you should not have to use cement to install the diaphragm gasket on these particular pool filters. Here is a copy of the owners manual for this model. It has a diagram of construction in case you need it to figure out how to get the replacement part on the filter.
May 08, 2011 | Hayward EC-40 DE Pool Filter with pump
Need the carburetor assembly manual
It is either a Walbro or a Zama carb. I think both mfrgs have a website w/ parts breakdowns. But both carbs are the same as to the placement of diaphragms + gaskets. On the side with the inlet needle the gasket goes on first and then the metering diaphragm. On the fuel pump side the diaphragm goes against the carb body and then the gasket before the cover.
Aug 10, 2009 | Troy Garden
Repair a Mackie SRM 450 Speaker The Speaker is making a crackling sound while playing. The sound keeps cracking up.
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Jul 20, 2009 | Music
Need a fuse box diagram 1992 achieva
Need a fuse diaphragm for a 1992 Oldsmobile achieva
Mar 29, 2009 | 1994 Oldsmobile Achieva Special Edition
Vacuum diagram of Mercedes 190D, 2,2
neto 190D: You are asking about a vacuum diaphragm?
I'm going to take a WAG.. Your engine won't shut
down with the key?
If so, he is the way you find out:
In your injection pump, the vacuum diaphragm which kills the engine is the one which has the fitting pointing parallel to the ground.
The vacuum line which serves it is a brown/blue
To check the system, first check for vacuum in the line. Run the engine for a minute or so. Cap off the brown/blue line.
Turn the ignition switch off and then with hose in hand, uncap it and you should hear a hissing sound. If you have a vacuum guage, obviously, use it for the test, you need a minimum of 10 inches to kill it.
To test the pump diaphragm, you can rig a vacuum line to a known vacuum source close to the main "T". Run the engine and with the line connected to the diaphragm, connect it to the good vacuum source, if it kill the engine, the diaphragm is good. If you have a hand vacuum pump it would be more ideal, because you could check the diaphragm for small leaks.
If the diaphragm is bad, it is easy to replace on the pump.
The shutoff diaphragm lists for $86.00
Is my shot in the dark correct?
Even though I am a Nissan Master tech, I also specialize in Mercedes-Benz and specifically Diesels, so if you need help, I'm here. I went through a few Mercedes Schools and have been swinging Iron in Mercedes since the 70's
I might be a little more informative than the public library.
Mar 05, 2009 | 1985 Mercedes-Benz 190
2004 Mustang Factory Wiring Diagrams Logo
15 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
