Question about Boating
Navionics card does not have enough free space for updates
    Problem Solver:
  • 9 Answers
Try backing up your card then delete all of your routes, waypoints and saved graphs. After you do the update you can put everything back on.
Posted on Jan 11, 2014
2 Suggested Answers
SOURCE: global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Posted on May 12, 2009
Why Does my Phone Stop Downloading Aps or Updates and Saying Not Enough Space on my Phone despite having 14GB Free on the SD Card?
Downloads and such are not going to SD card. They can be moved to SD card later. You should move some stuff to SD card to free up memory.
Feb 26, 2015 | Cell Phones
My IPad worked well with Navionics untill few days ago, then following problem appeared: when running my boat with trolling speed ( like 2 mph) the screen shows my position on map with the red arrow and...
Go into Settings - Navionics App and make sure that Mobile Data is enabled and also Background App Refresh. Finally, Location set to Always. It sounds like it is not being updated, but just setting your position on opening.
It is not a particularly good app and very basic although I have not tried the Paid version. I have a Humminbird 998 HD Side Imaging and the Navionics Mappind SD Card which gives much better results.
Aug 05, 2017 | Lands Phones
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Global map 5200c loading problems- navionics platinum hot maps
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have...
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Apr 22, 2009 | GPS
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Navionics gold card & humminbird 78c2
Hi!
You NEED to have a gps lock in order for the card to show it's true potential.
Also check in the menu for a setting that says "Map detail" and change it to all available. It could be the setting is on a lesser choice (like the internal mapping and not the new sd card)
Hope this helps!
Mike
Aug 06, 2008 | Navionics: Gold+ Chart Cartridge
Can not get a program to read my navionics sd card I have windows xp
Raytech Navigator software reads navionics cards and even comes with a card reader for an sd card. It also works on windows xp. Navionics also sells PC software to view their cards.
Here's a Raytech link:
http://www.raymarine.com/Default.aspx?site=1&section=2&page=710
Jul 26, 2008 | GPS
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
