Question about Yamaha RX-V995 Receiver
Can't turn to dts - Yamaha RX-V995 Receiver
How do i fix my remote to work my home theater. i have a htp-071 and my remote stopped working. the battries are brand new. I went away for the weekend and came home, remote didnt work. please help.
Test remote for operation. Problem is with either the remote or the receiver in the home theater.
Clean all battery contacts and install new, tested, working batteries in remote. Turn on am radio and tune AM dial to about 600 - turn up volume. Then bring remote to about one inch from radio and hit button on remote. You should hear a beep as long as you hold the button down. Every button will respond likewise. If nada at all remote is trashed, if works with some buttons then you have a partially operating remote. Try cleaning contacts for buttons that do not work or use some aluminum foil under those non working contacts.
Nov 22, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
2006 Cadillac DTS , #rd brake light, AND no trunk operation
Assuming the center high mounted stop lamp (LED) is OK, both symptoms point to the BCM but in the case of the trunk the valet switch could be on or shorted to turn on.
May 01, 2014 | 2006 Cadillac DTS
Stuck eldorado key in DTS ignition now car won't start
Make sure your steering wheel isn't locked. Sometimes a key won't turn until you jiggle the wheel while trying to turn the key.
Aug 21, 2012 | 2004 Cadillac DeVille DTS
2007 Cadillac dts cigarette lighter fuse
You will find all the fuses under the back seat driver side.
Jun 18, 2012 | 2007 Cadillac DTS Sedan
How do i get DTS 5.1 to work on my Panasonic SCPT570EBK surround?
i have the same problem XD. the stereo and surround are working but when i turn it to DTS it wont work. i hope some1 can slove this problem ty
Aug 25, 2009 | Panasonic KX-TG1033S Cordless Phone
DTS Doesn't works with my PS3
there are a few versions of DTS. if you are enabling DTS HD master on the menu for a blu ray disc this only outputs through the HDMI port not optical. This goes with all the new versions of DTS. If it is just DTS 5.1 it should go through. Make sure you have all the latest updates for your PS3. Make sure you are enabling DTS in the PS3 menu for optical out.( i dont own one so i dont know the menu at all) I just want to help. I hope this helps alittle and good luck with this.
Feb 20, 2009 | Panasonic SC-HT920 System
Cant turn on dts on dvd player
First check that the DVD has DTS (digital theater sound). Then you may need to change the audio option. In the main menu of the dvd go to sound options or set-up and check that its not 5.1 or some other audio option and is in DTS.
You did not list the make or model of your dvd player and or receiver, It would help if I had this info.
Jan 28, 2009 | JVC TH-C5 System
I cannot seem to get DTS-HD master to show on the receiver screen
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Dec 13, 2008 | Onkyo Audio Players & Recorders
Yamaha RX-V995 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
