Canon imagerunner 3570
I can't set my copy with less bright, the copy result is always too dark, what should I do? (IR 3570)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Reset the machine to factory default
Posted on Dec 30, 2013
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
  • 37 Answers
SOURCE: how to change the port number of canon imagerunner
On the control panel select additional functions- system settings- network settings, then scroll down for e-mail settings. The port can be changed there. You can also type the IP address of the copier in internet explorer, and change it though that interface.
Posted on Jul 29, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
SOURCE: i need explication :
code E00024-0001 canon IR 3570
Posted on Dec 14, 2010
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
Posted on Aug 25, 2011
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Aug 22, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I would like a review on the Canon imagerunner 3570.
Hello joy,
I have worked on copiers for 23 years, primarily Canon. I personally think its a great little copier. As with all models of copiers it has a quirk or two. The document feeder needs a few adjustments to minimize multi sheet feeding. But all things considered, when I get a service call on a an IR "70" series copier I feel no stress. Very dependable. The IR 70 series is feature rich out of the box and may be "expanded" in many ways. Lord I sound like a salesturd. But anyway that's just one opinion. Good day to you ! :-) SPINAL
Apr 01, 2011 | Canon imageRUNNER 3570 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
I can't get my Canon ImageRunner 3570 to print in color, how do I get to that setting?
The Canon IR-3570 is a black and white copier, printer only, it's is not a color printer. sorry
Dec 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
E000007-0000
this code is for damaged fixing film, on the end you have home position sensor for good position of fixing film.
Feb 04, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 3570
Can anyone pls let me know the procedure to scan a document using Canon IR3570?
Mar 28, 2008 | Canon ImageRUNNER 3570 Copier/Printer
Canon iR 3570
Oct 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
75 people viewed this question
jasbo
jasbo
