Question about Hoover WH10600 Air Purifier With Ionizer
The red light on my Hoover wh10600 will not change back to blue. Why is this? I changed the bulb and put a new hepa filter. Please help!
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
How do we change filters on a HAP8650 air purifier?
"After replacing the HEPA filters, RESET the Filter Life Monitor by inserting a small object (such as a pin or paper clip) into the hole below the red filter change light marked RESET and holding it down for 2-3 seconds." This came straight out of the Owner's Guide. Hope it helps!
Sep 13, 2012 | Holmes HAP8650 - HEPA Allergen Remover for...
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
I want to change filters. please help
Hi and welcome to DixYa, I am Kelly
The only two parts requiring any service are the activated carbon pre-filter and the HEPA filter. No tools are needed. To change either filter, disassemble the unit as shown.
1. Loosen the carrying handle by turning it counterclockwise and lift filter cage cover from unit.
2. Lift HEPA filter and activated carbon pre-filter from the base.
3. Remove the fasteners from the activated carbon pre-filter and remove it from the HEPA filter cartridge.
4. Replace filter(s) as needed, and discard used filters.
5. Wrap the activated carbon pre-filter around the HEPA filter cartridge and secure it with the fasteners provided
Pictures are here:
http://www.american-allergy-supply.com/hd/hwc.htm
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Honeywell Enviracaire 13520 Air Purifier
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
May 04, 2011 | Kenmore 335 CADR Air Purifier
Turn off reset button
IF RESET DOES NOT WORK DON'T WORRY
AS LONG AS YOU REMEMBER TO CHANGE
THE FILTER. CHARCOAL WHEN DIRTY AND
HEPA ONCE A YEAR OR SO.
Mar 19, 2009 | Whirlpool Whispure (45030) Air Purifier
Red light on...
the unit probably needs to be reset. cause what's happening is that it's not recognizing that the filters are clean. there should be a tiny pin hole at the top of the unit. when the unit is on you need to put a small needle in there and hold for about 5 seconds and the unit should reset. if that doesn't work please please let me know and i will see what else we can do.
Mar 12, 2009 | Holmes Products HAP725-U Air Purifier
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Red filter indicator light
    Hi Linda - there is a "reset" hole - you have to stick a pin or a paper clip in the hole when you change the HEPA filter - I just found this out myself! It does work. Mine didn't work right away, but it did end up resetting and went back to green after a few moments. I think this happened to me last time. The filters are really expensive, but you can get them at Walmart. If you need more information, email me at marixyz@aol.com and I'll tell you what model filter, etc.
    Nov 05, 2007 | GE HEPA 106653 Air Purifier
    Hoover WH10600 Air Purifier With Ionizer Logo
    163 people viewed this question
    Top Hoover Air Purifiers Experts
    Thatvacguy.com
    Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
