Question about AMP Fuse Wiring Panel
Where is the location of the interior fuse box on a 2007 pt cruiser touring
The wiper and turn signal are dead and I see no fuse box under steering or glove box.Is there one fuse box or two?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Open the drivers door and look there
Posted on Dec 30, 2013
Where is the interior fuse box? It's not on drivers side under steering wheel
Hi Robbie,
There is No Interior Fuse Box on the 2006 PT Cruiser.
  • All of the fuses are on the box under the hood on the right side just behind the air filter housing.
  • You have to press the tabs to remove the fuse box cover.
Good Luck,
JP
Jun 28, 2015 | 2006 Chrysler PT Cruiser
Where are the fuse boxes for a 2007 PT Cruiser?
Usually there are two fuse boxes. One located under the hood which is labeled, the other is under a panel on the side of the dash which is concealed when the drivers side door is closed.
Feb 12, 2015 | 2007 Chrysler PT Cruiser Touring Hatchback
Does anyone know the exact location of the interior fuse box. wiper and turn signals are out of a 2007 pt cruiser or if the fuse box in the engine is the only one
open the drivers door and look up by the door hinges... if you are working on a pt cruiser I think that's where it is... should be a little lift off cover
Dec 30, 2013 | 2007 Chrysler PT Cruiser Touring Hatchback
Where is the fuse for the tail lights on a 2007 pt cruiser?
all the fuses should be in the fuse box either under the hood or under the dash......cheers
Aug 16, 2011 | 2007 Chrysler PT Cruiser Touring Hatchback
I HAVE A 2006 PT CRUISER THE REAR WIPER JUST STOPPED WORKING
The wiper motor may have gave out its located in the rear hatch interior panel. Although your problem could simple be that the fuse has blown and do need to replace it. Generaly the fuse panel is located directly under the dash panel and some times in the glove box. The only other promlem whould have to reside id a bad wiring conection simply use a voltage meter to check continuity.
Dec 06, 2010 | 2006 Chrysler PT Cruiser
No turn signals,wipers,or hjgh low headlights,nothing working onn steering wheel except horn.
You need to check your fuses, if that isn't the issuse, you need to remove the shroud around the steering column - and see if the wire are connected and tightly. If thats not issue, you made to replace the switches that control that. Dodge will sel them for an arm in a leg, try Car Quest or Napa, they can an OEM after market part that works great.
Oct 31, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
2007 PT Crizer does it have an interior fuse box my ac fan is not blowing
I will answer this if you rate, by checking one of the four thumbs up! Just kidding. I will tell you. There is a relay on the passenger side under the dash. If you take your hand and bump the dash pretty hard under the glove box I bet the fan will come on. There is a relay under there that is not pulling in. You need a new relay!
Sep 16, 2010 | 2007 Chrysler PT Cruiser Touring Hatchback
My front windshield wipers will not shut off..tried to locate the fuse to pull it out but there is no indication on the fuse panel. Do you know which fuse it is?
under the hood, u will find a relay just for the wipers, just pull that out. may pay to install a new relay as i have found a few go bad and cause the wipers to continue to run
Jul 08, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Fuse box location
Fuse box is under the drivers side under dash panel by the pedals.
Apr 07, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
AMP Fuse Wiring Panel Logo
Top AMP Car Audio & Video Experts
bigdawg7299
Billy McCain
Billy McCain
Level 1 Expert
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
