Question about Hobart Dishwashers
HEI error Rinse booster heating defective - Hobart Dishwashers
Prob error final rinse
Probe Error FnlRns - (Ensure that the supply water valve to the final rinse booster is open.)
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F44126.pdf
Apr 27, 2015 | Hobart CLPS66E-16 L/R 15KW Tank Heat...
Meiko error 203
203 No change detected by level switch during rinse pump operation
Level switch defective/disconnected, booster pump defective/disconnected, start cap defective/disconnected, no signal from I/O board, check microswitch manually.
This is per their service manual.
Jul 17, 2014 | Meiko DV 80.2 Dishwasher
Error codes 206
206 Increase in wash time Booster not ready for rinsing at right time. See error code 205.
205 Temperature increase not reached Booster heater not working, heat elements are open, defective temp sensor.
Per the service manual
Jan 06, 2014 | Meiko DV 80.2 Dishwasher
After 20 mins water temp still not at 150 on my jet-tech 737 dushwasher.
The reason the temperature are going up is the heating system is defective. The thermostat on the booster (rinse) is not satisfied. First thing to verify is the contactor that is activated by the rinse thermostat. Often one of the wires on the contactor will burn.
Nov 20, 2013 | Jet Tech Systems 24 in. 737 Free-standing...
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Aug 31, 2006 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
