Question about Bosch Hammering
Bosch 11305 trying to find seal kit
  • Bosch Master
  • 1,828 Answers
803 1 617 000 036 is the ordernumber all is include .
Posted on Feb 26, 2016
How to fix Bosch Pressure Washer to stop Leakage water from Machine
if the pump is leaking it will need a seal kit to fix it most likely
May 17, 2017 | Bosch Washing Machines
Bosch gsh 10c is not hammering
Likely the hammers are broken inside the drill.
Oct 07, 2016 | Bosch Drills
Model 11305. how can I lubricate?
This is the same (only 110V of an old European Bosch USH 10 C demolition hammer a 20 years ago i had this hammer yet regular in service and you need at least but ALLWAYS the pos number 803 i hope for you its orderable i think it does because of the many pieces of this popular tool. ordernr 1 617 000 036
Feb 13, 2016 | Bosch Hammering
What gear lube to use
1 bottle of 50ml oil BOSCH 1 615 437 511
But also a special kit thats neccesary if it had its working hours and was leaking in the front .
Not only a seal and o-rings to change is not enough
1 special kit BOSCH 1 617 000 430 if all parts are replaced don,t forget also to change the O-ring 1 617 000 430 on the right place see first how its fitted its included in the kit with seals but remarkable the oil is not allways in the kit
Feb 06, 2016 | Bosch 11241EVS SDS-Max Rotary Hammer
I have a Bosh, model no. 11232 EVS Hammer Drill, but do not have the service manuel, and would like to know how to service it, how and when.
Many people service their hammer drill when it begins leaking, stops hammering, or just quits running. Bosch makes a service kit that comes with brushes, grease, and all the o-rings and seals their own technicians at the Factory Service Center use to rebuild the tool. 1617000263 is the part number for the service kit, and costs under 50.00 . The unit will have to be torn down and cleaned(everything forward of the armature). If you dont do it for a living, it can become quite a project. Try to avoid bringing into a service center disassembled, because they will charge you more than if you just dropped it off for a rebuild.
Nov 16, 2010 | Bosch Drills
My dishwasher sounds like it has a grinding noise when it is first turned on and through out the cycle.
you have a wash pup seal failure water will enter motor bearing causing metallic wine new motor and seal kit will be needed.
Jan 11, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Impeller is going bad. What will cost to fix on a Bosch shu 9990
Hello there
Normally you will want to get the impeller kit for this it will include the seal for the impeller
Drain & Wash Impeller Kit - Comes with drain & wash impeller, pump seal, chopper, gaskets, screw and instruction sheet.
Part Number: AP3115180
Our Price: $29.00
this is a quote from parts select.com
and is usually a fairly normal price
ok hope this is very helpful for you
Best regards Mike
Jan 06, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
How do i get a bosch front loader drum apart, to get the bearings
THIS CAN BE DONE EASILY WHEN YOU HAVE DONE A FEW LIKE ME, HOWEVER FOR A BEGINNER ITS QUITE INVOLVED IT TAKES ME A COUPLE OF HOURS TO DO.YOU WILL NEED A NEW REAR TUB SECTION COMPLETE WITH BEARINGS A TUB SEAL AND A SEAL KIT (NEW BOLTS INCLUDED) AND POSSIBLY A NEW INNER DRUM AS REMOVING THE INNER DRUM FROM COLLAPSED BEARINGS IS NOT EASY WITHOUT DAMAGE TO DRUM SHAFT,IF YOU STILL FEEL CONFIDENT REPLY TO MY POST AND I WILL GIVE YOU MORE ADVICE.
Sep 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Breaker Hammer Service Kit Install
The grease in the upper drive area used to be a purple looking grease and the grease in the barrel was a different color and weight. If you ordered the rebuild kit with the O rings and bolts I would use it in the barrel (light film coat on the parts )
May 10, 2009 | Bosch Brute Breaker Hammer 11304
I need a replacement rubber seal for my Boch front laod washer Model# wfmc3200uc/01. I also need the plastic peice that holds this seal in place. I have only had this washer for a little under 1 year is...
It all come in one kit: plastic front cover and boot gasket.
Part # 246270.
Manufacture warranty for Bosch washer 1 year from day of purchase.
For assistance with your Bosch home appliance
or to order spare parts
1-800-944-2904
MON - FRI ~ 5AM - 8PM PST
Also you can buy from here:
http://www.marcone.com/
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Dec 10, 2008 | Bosch WFMC 3200 Front Load Washer
Hammering Logo
184 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
