Question about Video Game Consoles & Games
Mine is a Vortex Revonix 360 Blaster Just bought
Mine is a Vortex Revonix 360 Blaster Just bought it and after shooting a few rounds something jammed
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
I bought a Tommy 20 Air Blaster for my grandkids and after an hour of working with it, I still can't get it to shoot a dart. All it does is jam.
Fold back the blaster's Barrel, You should see a Orange square section with two copper metal pieces inserted in them on both the barrel and the cylinder housing those pieces connect are the both still intact? uf not You may have the same problem as I do.
Jun 26, 2011 | Buzz Bee Toys Air Blasters Motorized Disc...
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
I can't play with my partner wiyh the second controller I bought. How to connect so I can with my partner? Second one: I'm struggling to connect to internet. It keeps on sayinf timed out when I search?...
You don't say which console you are using. You need to reset second controller so the console can locate it.
If xbox 360 there is a very small round button on back edge of controller. You need to press this button and then also press the small round button on the front of the console. The lights will start flashing and after a few seconds the console should recognise second controller and you will have 2 green light lit up in the circle round the consoles power button.
If PS3 you need to press reset button inside a small hole on back of controller. YUou need to use a paper clip or something that will fit inside the hole. You may have to plug the controller into the PS3 using the USB cable and press PS button on the controller too.
Dec 17, 2010 | Video Game Consoles & Games
How do I switch the Topeak mini master blaster pump for presta valve operation? It looks like there's a plastic washer that needs to be reversed but it's impossible to remove.
i've just bought one, they seem pants, un screw the cap, theres a remove the rubber part, tap out the green bit, then just switch it round.
but i've tried pumping my tyre but nothing seems to happen
Sep 03, 2010 | Topeak Mini Master Blaster
Xbox 360 Controller Won't Connect To My 360....
You have to connect the controller like this: Somewhere on the XBox 360 controller there is a button that looks like this, o))) or something like that. Push that button and look at the XBox 360 round lights, they start to flash, that means you have to push the same button on the console. The o))) button should be infront of the console.
Regards,
Max
Jul 09, 2009 | Microsoft Video Game Consoles & Games
Powerfast strap gun for romex misfiring
just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
Nov 17, 2008 | Tools & Hardware - Others
Mad catz drteam blaster
dude im not so sure about this just one tip is dont ever buy madcatz stuff!! PLZZ!!!
i cant help sorry! :(
Dec 27, 2007 | Mad Catz Dream Blaster (7188) Light Gun
Video Game Consoles & Games Logo
70 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
