Question about IBM 92P1101 (4400 mAh)
Charge t40 laptop battery
Charging circuit on the laptop doesn't charge anymore. What is the pinout and input V and mAh for the 92p1101 battery. Betcha don't know!
    Top Expert:
  • IBM Master
  • 44,126 Answers
Betcha IBM might be able to tell you. Ask them.
Posted on Dec 30, 2013
How to charge my ASUS epc1000heb-blk001x battery
The battery charging circuit inside the netbook is much different that using a dc power supply. You'll fry the battery using one.
Jan 04, 2014 | Battery Biz Computers & Internet
New battery 6600 mAh does not charge anymore
It is possible it is a bad battery again. Also could be a bad solder joint on the DC jack or bad AC adapter. To test power off and unplug the laptop, remove the battery. Now plug in the AC and power on the PC. If it comes on, gently wiggle the AC plug going into the PC. If it shuts off you have a bad DC jack solder joint. If it stays on the battery is probably bad or the battery connector on the PC. If the PC doesn't come on at all with just the AC gently wiggle the AC plug and tap the power button repeatedly. If it comes on briefly than off again it is the jack solder joint. If it doesn't come on at all then it's a safe bet the AC adapter is bad.
Apr 17, 2012 | Acer Computers & Internet
My dell battery will not charge anymore. it says
Charging circuit on motherboard or you can try a different A/C adapter. Start with the adapter first, they're pretty inexpensive $20-$35. If that doesn't fix it then a motherboard replacement is your solution unfortunately. Check with Dell on your warranty options.
Jul 12, 2010 | Dell Inspiron 1525 Laptop
I was charging a traxxas 3000 mah battery at 3.0 amps and after 28 min 43 sec it showed a full charge but only input 1334 mah. i have charged this battery only 2 times previously on this charger and...
You are not doing anything wrong, chances are that you just did not fully discharge this battery before charging. You will notice that all batteries will vary from charge to charge, but this is normal. Have fun with the cars. Hope this helps.
May 06, 2010 | Kitchen Appliances - Others
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I replaced motherboard on nc6400 new battery new charger but still not charging what can be the reason???? the laptop work on AC power Work on the new battery i charged it on other computer????
Because of BIOS. Basic Input/Output System.
Battery has 'lost track', of what the battery state of charge is.
Try Recalibrate BIOS
http://laptopbatterynews.com/2009/04/22/bios-says-to-recalibrate-my-laptop-battery/
Aug 21, 2009 | Computers & Internet
WHICH VOLTAGE HAS THE 2 BATERY PHILISHAVE TYPE HQ 6740/A
Input voltage : 100-240 V, 50/60 Hz
Power consumption : max. 9 W
Motor voltage : 2.4 V
Battery : 2x NiMH AA
Battery capacity : approx. 1100 mAh
Charging indicator : 1x duoLED green / red
: charge / battery low
Charging time : approx. 8 hours
Charging current : 200/25 mA time dependent
May 21, 2009 | Philips Philishave Cool Skin HQ6740...
Battery will not charge
I purchased a Genuine Dell Battery, It arrived dead with 1 test light on battery itself at 0% charged, It only lasted 2 mins before the laptop died running on battery, It doesn't charge the Dell battery at all The replacement battery only shows a 1% charge every 7 hours or so, nor do I have a yellow, green, orange light, The only time I get a light on the battery led is if i'm running on batteries and the battery level is below 10%, Its orange for low battery.
Thanks in advance to anyone who could help me.
Oct 31, 2007 | Dell Latitude C640 Notebook
IBM 92P1101 (4400 mAh) Logo
48 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
