Question about Kitchen Appliances - Others
How do I convert a car to run on propane - Kitchen Appliances - Others
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
Take it to a mechanic that can certify the job or you could blow yourself up! This is not a DIY job
Posted on Dec 30, 2013
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
Can I convert a 450rb from propane to natural gas
The simple answer is yes. However you will need to convert it. Simple process for a gas fitter, they will put a natural gas regulator on and possibly change the jets. Natural gas runs at a higher pressure than Propane. What ever you do, do not run without conversion, it will fail with possible fire or explosion.
Oct 04, 2015 | Kitchen Ranges
Truck runs on propane does not start
Are you familiar with the propane injection system? If so can you tell me what tests you have run so far and what was inspected? Do you have a fuel type selector switch (to choose between Gas and Propane)?When did this problem start and what is the temperature outside? Propane will not convert from liquid to vapor fast enough, if it is too cold outside. Inspect the plumbing between the intake and the regulator. If there is a leak in the plumbing. The diaphragm inside the regulator will not move or open (to let propane flow to the engine). The regulator can malfunction if it becomes clogged with sludge from the propane. They sell a product that can be added to the propane tank. It is used to keep the fuel system clean. Please write back. If you have more details or information I would like to help. Good luck.
Dec 29, 2013 | Cars & Trucks
Troy Bilt 8000 watt generator is not puting out full 120 Volts after converting to run on propane.
if the rpm's are not right the voltage regulator can't put out more than its putting out
May 28, 2012 | Garden
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Appliances - Others Logo
32 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
