Question about Weslo Cadence 805 Treadmill Walking Belt
How do I adjust the belt on a weslo cadence 805?
SOURCE: Weslo Cadence 1010 incline instuctions
do a search. theres a free website that offers a free manual download.if the incline hardware is fine you should be able to lift it while its in its lowest setting of the floor. its got a rachet type that lifts the end of it making it less incline.
Posted on Jan 25, 2009
mohtwister
  • 37 Answers
SOURCE: Lost owners manual
try this: http://fitness.owneriq.net/manuals/mfg/weslo/cadence_450_model_no_wltl35520.html
Posted on Jun 02, 2009
  • 16 Answers
SOURCE: i have weslo cadence 860 ,the key is not working
Is it the magnetic key or the red one you slide into the slot.
Posted on Jun 29, 2009
SOURCE: lost key for my weslo cadence 860
We found the key.
Thanx
Posted on Sep 03, 2009
hasan mahmud
  • 35 Answers
SOURCE: weslo cadence treadmill fuse keeps tripping after
dear sir,
this types of problem occurred due to reason given below:-
1) if your motor belt too jammed. motor need more power to rotate it.
2) motor internal coil insulation problem.
3) semi short circuit in the internal control circuit.
how to check :-
at first look the label on motor try to find out the motor Ampere then measure with a ammeter if it drawing current is high from label mentioned ampere
then motor is faulty.
for check the circuit if u don't have any previous idea plz contact with qualified technical person.
hope that u get the answer.
thanks
Posted on Oct 22, 2009
Adjust incline on weslo cadence g 5.9 bought it used no manual
On the rear of walking deck you have the left and right feet. Down the deck is at 0 degree incline, fold them up and you have a 3 degree incline.. You have no incline motor on this model.
Mar 02, 2015 | Cadence Weslo 825 Treadmill Walking Belt
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
The walking deck on my Weslo Cadence 975sel slides to the right and causes a loud rubbing noise. How can I correct this problem? Thanks,
Find the allen key that came with the machine. If you don't have it, you will need a 3/16" allen key to adjust the roller.
If the belt is pulling to the right, adjust the right screw by turning it clockwise 1/4 turn with the belt moving. You may need to do this more than once. Between adjustments, watch the belt closely to see how much it moves to the left.
Unless something dramatic has happened to the frame or some other part, the amount of adjustment should not be too great..
Dec 17, 2010 | Treadmill Doctor Weslo Cadence 930...
Lost my weslo cadence 805 manual. Need to download one
You can go to iconservice.com to download your manual. When you get there just fill in the model and you will be able to download the manual.
Hope this is what you were looking for.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 12, 2010 | Cadence Weslo 927 Treadmill Walking Belt
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Walking belt slows down to almost a stop when i get on it
I believe under the motor shroud on the circuit board their should be 2 pots 1 adjusts torque 2. adjusts speed try adjusting them and see if that take care of the problem if not. worse case it might be the drive motor.
Feb 27, 2010 | Cadence Weslo 4200 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence 805 Treadmill Walking Belt Logo
35 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
