Question about Ovens
Fuse location on ge stove
Oven Element not working. Wondering if it's a fuse. But can't find the fuse panel.
  • 468 Answers
If there is a fuse it should be located on the back of the unit behind a cover plate.Make sure to unplug stove before working on it.Hope this helps.
Posted on Dec 30, 2013
aborcass
  • 2651 Answers
SOURCE: ge oven fuse
checkin model # jkp15, f3 shows up as a shorted oven sensor here, No fuse even shows up for this particular model
Posted on Feb 23, 2008
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
SOURCE: GE P7 Oven 2 burners out on stove top
Purchased a new stove.
Posted on Dec 27, 2008
  • 59 Answers
SOURCE: GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Posted on Jun 19, 2009
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Ovens
The lower element in my Admiral Sentry stove is not working. there is no layout for fuses so not sure what fuse needs replaced
It is not a fuse issue. Turn off the power to the oven. Remove the screws from the lower element. Pull the element out carefully. DIsconnect the wires. Take a volt/ohm meter set for ohms or continuity. Touch the 2 leads from the meter to the 2 element wire terminals. If you get no reading,replace the element with a new element.
If you do get a reading reinstall the element and replace the oven control.
Sep 21, 2009 | Stoves 720EF Electric Double Oven
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Jun 12, 2009 | GE Ovens
Fuse location
are you talking about the breakers that are outside or in the garage? Look where the main power goes into the building and there is where the breaker for the oven should be.
Dec 24, 2008 | GE Profile JT952 Electric Double Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
My ge spectra stove bake element is not heating
Dec 18, 2007 | GE JKP20 Electric Single Oven
Ovens Logo
382 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
