Question about Whirlpool Washing Machines
Cabrio washer WTW6500WW1 Stopped working in the middle of a spin cycle. Now I can plug it in and press power, everything lights up, but none of the controls work. If you spin the dial it will stay lit where it initially was no matter what setting you turn to. I THINK it sounds like the interface is bad?
  • james
    james Dec 30, 2013
    After unplugging and turning it back on I got it on spin, so it drained. When I plug it in the control panel works for a few seconds, then no matter which button you push, even power, it just beeps and wont respond or turn off.
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Assume its still full of clothes and water?if you take the drain pipe from the wall and hold to ground all water will drain out(youll need a bowl/bucket)it may then allow reset but more likely something is blocking the pump,if theres a hatch at front after draining open (machine unpluged)see if you can turn the pump with your fingers if in doubt ring engineer but if u are ok then pump may have to be disconected from big pipe to remove a blockage,machine will reset when done
Posted on Dec 30, 2013
kaienana
  • 10 Answers
SOURCE: Maytag Ensignia Oversize Cap Plus Washer stopped working in mid cycle
Check the water level control, it could be stuck or faulty.
Posted on Jul 07, 2008
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Posted on Sep 30, 2008
  • 7 Answers
SOURCE: Whirlpool Cabrio Washer
it is the bearing, call 1800-905-9505 and ask for a service smart agreement cost about 200 and it will cover your washer for 1 year parts and labor and the machine will get fixed
Posted on Mar 19, 2009
honeymokey
  • 3113 Answers
SOURCE: Washer will not stay balanced on spin cycle no matter what size load.
The tub brace or spring may have come loose.
Posted on May 05, 2009
marka19
  • 1430 Answers
SOURCE: "Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 01, 2010
What is load capacity for cabrio wtw6500ww1
It may only think it's overloaded. When the cycle starts the control checks the load to determine how much water to add. If there's a problem like stuck basket or rotor, bad sensor etc it will quit with the error you see.
Jun 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw6500ww1 stopped working when it needed to spin n drain?
get a putty knife and between the top and cabinet about 2 inches in on the left and right shove the putty knife in to depress pins (this can be frustrating) once you can lift up the whole top you will find a tech sheet in the inside of cabinet left . also you will need to do this to replace lid switch. run through diagnostics to view all errors . there will be a list of error codes in this tech sheet with troubleshooting ideas.
Feb 17, 2013 | Washing Machines
Cabrio washer will not start
I have one doing the same thing it washes but will not rinse.So until I can do better I just use the wash cycle twice first with detergent and once without.
May 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5600xw0 will not spin
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
May 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6500WW1 stops spinning.
Hi there
The ideas I have are sort of homemade. What I did wrong was that I did not let the machine rest long enough between starting the machine for it to stop a while later.
good luck
kolbrun
Mar 18, 2012 | Whirlpool Washing Machines
The display panel is beeping and flashing LD...after the washer stopped running in the middle of a cycle
This error code indicates that drain times are longer than expected. Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Click the following to learn more about proper drain systems for Cabrio washers. The example shown is for an impeller washer but is applicable to washers with agitators: whirlpool.com/files/usr/animations/ANM000014
Keep in mind that to remove the error display, press Pause/Cancel once; if does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and both of the questions above have been checked, call for service.
Hope helps.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
