Question about Sony VAIO Notebook
I had plugged my computer in the other day, turned it on and it worked fine. I put in a flash drive to copy somethings to it. Put the flash drive in, finished with what i was doing powered down and everything seemed fine. A few hours later I turned it back on and it says "OPERATING SYSTEM NOT FOUND".....
    Habit-Forming:
  • 188 Answers
I guess you tried restarting the computer a couple times. You didn't accidently send the "C" drive to the flash drive? Have you tried putting the flash drive back in (if it hasn't been changed) and tried booting?
Posted on Dec 30, 2013
gnkanang
  • 63 Answers
SOURCE: No operating system found after ran recovery disk
Hi
Sorry, to hear that, but it seems you will need to reinstall wounds.
Sorry!
Posted on Mar 25, 2009
SOURCE: I spilled a little white wine on my Gateway laptop
Please remove the Battery from the Battery bay and disconnect the AC Adaptor from the Notebook. Then, clean the metal contact in the Battery Bay and leave the Battery removed for half an hour. Next, connect the AC Adaptor to the Notebook and the power cable to a functional wall outlet and try to turn ON the Notebook. If the power LED on the Notebook doesn't glow then again disconnect the AC Adaptor and try removing and reinserting the RAM module. If the issue persists even after performing all the above steps then service will be required.
However, if the Notebook turns on after performing the above mentioned steps but the Battery is not detected then perform C: Drive Restore using the VAIO Recovery Center.
As per the specification published online, the Computer model VGN-N250E is preinstalled with the VAIO Recovery Center in the hidden partition of the Computer. You may use it to perform C: Drive Restore to restore the Computer to the original factory settings. Please make sure that the new Battery is installed in the Computer while performing the Complete System Restore.
Performing a C: Drive Recovery will erase all the data present in the C: Drive only and will reinstall the pre-installed Operating System, Applications and the original Drivers supplied with the Computer.
Please restart the Computer and keep on tapping the F10 key to access the VAIO Recovery Center. Next press the Enter key then select the "VAIO Recovery Center" option then follow the steps given in the link mentioned below to proceed with the C: Drive Restore.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C473668
In the link given above, please click on the sublink "Restore C: Drive" to view further information on performing the C: Drive Restore.
Performing all the steps successfully should resolve the issue.
Posted on Jul 12, 2009
  • 1015 Answers
SOURCE: sony vaio operating system not found when computer
You can try running the installation/recovery disc that came with the computer or the built-in recovery system (if it has one) to try and repair the windows installation. The problem is if the computer is saying that the operating system is not found then critical files got deleted from something like a virus or the hard disc drive has stopped working. You may have to do a format and re-install of the windows OS.
Posted on Nov 14, 2009
  • 111 Answers
SOURCE: Sony VGN-TX750P laptop Operating System not found message
try seating the hard drive, the HDD might have been loosened when you changed the part.
Hope it helps!
Posted on Feb 14, 2010
  • 195 Answers
SOURCE: help
Unfortunately it sounds as if the hard drive is clicking and not detecting because it has failed. At this point you will need to locate the operating system media for your system and purchase a new hard drive and start from scratch.
Posted on Jun 17, 2010
Sandisk u3 cruzer micro usb device stopped playing when put in car stereo. It was playing fine but now nothing my car stereo say's it's reading the device but thats it
You might try plugging it back into your computer, and formatting it. If you don't know how to do that, pull up the screen right BEFORE you would open it to copy music to it, right click on the flash drive, and click format. Format it with whatever the default format is shown (probably FAT32) and then copy your music back onto it. If that doesn't work, let me know.
May 05, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
HOW TO COPY AN BLUETOOTH DRIVER ON FLASH DRIVE
Hi to copy bluetooth drivers to your flash drive you need to plug the flash drive into the computer USB port locate the drivers you want to copy select the drivers then right click on the drivers and select copy, Locate the flash drive icon on your computer double click it and then right click on paste to put it on the flash drive.
Aug 08, 2010 | Computers & Internet
My files on my hard disk are corrupted whaat do i
You can try taking out the hard drive from the ps3 and hook it up to a computer that has SATA connections. Then copy the files to a flash drive. This way you can at least save the information from the hard drive.
At that point, put a new SATA hard drive into the PS3 and format the drive. Then at that point put the information that you saved to the flash drive onto the ps3 hard drive. Do this all in the computer after you format the new drive in the ps3 and then put it into the computer to copy the files from the flash drive into the new hard drive.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
How do i put pictures on a sandisk u3 4gb flash drive
You can put pictures on it the same way you put any other files on it. Plug the flash drive into your computer, then drag&drop any files to/from your hard drive(s).
Dec 13, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
It won't show up
Use the exact same USB port that you used to install it.
The installation uses a "virtual USB" port.
You also have to use the same user account on the computer. (Use the same USERNAME as when it was installed).
Also, check to see if the computer DOES see it:
Right-click [My Computer]
[Manage]
{Disk Management]
Find your Cruzer in the list or on the graph.
Right-click on it and [Explore]
Copy your homework to your computer desktop.
It should work ok, now.
Oct 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I just purchased an 8GB USB 2.0 flash drive from SanDisk Cruzer. I plugged it in, it recognized it then opened to documents what do i do next?
You use it like a floppy disk, you can copy files to and from your computer to the flash drive,then take the flash drive out and the put into another computer to share, ie. to download and copy files to from other computers such as a friend's computer. The files can be anything, music, photos etc.
Sep 28, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Acer ZG5 lsass.exe
Use another computer to copy the files from the CD over to a USB flash drive, if you have got one. Then start up you Acer and go into the BIOS settings (press F1,F2 or DEL a few times before the windows logo appears) Then go to boot device priority or something similar, and choose the priority to boot from a USB HDD higher than your Hard drive. Just to be sure, put it as number one. Save the settings and exit, and restart your computer with the USB flash drive with the files inside in your computer.
Jul 23, 2009 | Acer Aspire One PC Notebook
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Sony VAIO Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
