Question about HP OfficeJet 6110 All-In-One InkJet Printer
I haveHP 6110 all-in-one printer that I can make copies from my lab top computer by...clicking on print...connects to printer.....says paper jam...I then press "enter" on the printer....a sheet of pap
"press enter to align cartridges"... What can I do to remove this from the screen ....to get date and time back?
  • Cynthia V. Wright Dec 30, 2013
    ....a sheet of paper spits out...then my computer prints out my recipe from the computer, but I can not print from my glass top. Also, I had to put in a 56-black cartridge....after cleaning the blue light lens and cleaning color cartridge....the display window keeps saying "press enter to align cartridges".....How Can I remove this, so that the "time and Day shows up? ....Please Help.....Thank you
    I keep pressing "Enter" and align fails and all it keeps doing is spitting out clean paper.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
You may try to reset the printer per HP instructions.
1. Turn on printer with power button
2. With printer on, disconnect power cord from rear off printer.
3. Unplug power cord from outlet
4. Wait at least 15 seconds
5. Plug the power back into the outlet
6. Reconnect power cord to the rear of the printer
7. If printer does not come on, press the Power button.
Posted on Dec 30, 2013
Inkworks
  • 87 Answers
SOURCE: Paper Mismatch
The problem is the "spot sensor" that resides on the side of the carriage assembly. It shoots out a ray of light on to the paper when the paper is fed into the printer for printing. It tells the machine..."Hey...there's paper there, start printing". If this sensor is not working properly you will get the error that you are receiving. Most of the time the light still comes on but the sensor board cannot process. You will need to replace the spot sensor of which we have many of....There is a thin plastic piece on the right side of the carriage that covers this sensor. It removes easily so you can see what i'm talking about. Its very easy to replace as well.
Inkworks
Posted on May 21, 2008
SOURCE: hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Posted on Jun 01, 2008
leroyal
  • 2120 Answers
the ink inside of the cartridges is gelled.
Posted on Feb 06, 2009
SOURCE: Keep getting message Press Enter to Align Cartridges
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Posted on Feb 19, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: "Press enter to align cartridges"
Try removing the ink cartridges and cleaning the electrical both on the ink and iside the unit with some rubbing alcohol and qtip then reseat them back into the unit and see if that works
Posted on Feb 21, 2009
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Not connected to computer, constant "clicking" is
Please,
Check your firewire for malfunction. It may not connected properly or broken. Re install the driver if needed
Jan 09, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I get a paper jam every time I use my Xerox 6110 MFP Printer. It jams on every document while printing or copying.
same problem here expert at Xerox adviced to clean black rollers on the papertray
maybe it works for you, not for me though ;-(
Aug 11, 2010 | Xerox Phaser 6110 Laser Printer
HP all in one printer 6110 Computer says printer is out of paper, but printer doesnk't show any error messages. I have unplugged it and re- set it. It does have paper! I can copy a page from the top...
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
We can't take copies and prints with our hp officejet 6110 all-in-one printer.I think we've got this problem because;we haven't got driver for our printer. Thanks for help.
The person making the clarification request is right. Even if your printer isn't connected to a computer, it should still be able to copy. That means it probably isn't a driver issue.
I did find a page at the HP web site that talks about troubleshooting copy problems. The web page is pretty long but the link I'm providing should open the page to the right section:
Nothing happens when the copy button is pressed
Since you can't copy or print, it may be that the two problems have the same cause, such as a paper jam. Take a look at the contents on that link and see if it helps. Post back your results. Good luck.
Sep 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Will not print
We will experience this issue if the documents are pending on the printer icon or if the printer icon is paused. Check the status of the printer icon in control panel and clear all the pending documents and make it online if it is offline and then try to print.
Apr 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer says paper jam, but no paper is jammed
Check the following information.......
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
or
most of the time for a paper jam, there is a QUEUE of papers waiting to be printed. id take out the usb cable via the back of the computer {the one that connects to the printer} go into the control panel, look for printers, double click on that, find the printer, it should say {working offline} right click that, choose the uninstall/delete opts. turn off the printer. reboot the machine, wait until it boots all the way up. take the printer, turn it on, then plug back in the usb cable to the back of the machine. if it is windows either xp/vista it will auto find the usb cable and install automatically. you can then go back to the control panel, printers and it should be listed in the directory. try to right click go to properties of the printer and do a TEST PRINT, should print out.
Jan 31, 2008 | Xerox Phaser 6110 Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
