Question about Frigidaire Electric Dryer
Frigidaire dryer smells fish odor
Fishy smell
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Well then clean your fish in the sink... or check for a leak and you might find some mold
Posted on Dec 30, 2013
  • 142 Answers
SOURCE: My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Posted on Jan 25, 2009
dragonsthatk
  • 547 Answers
SOURCE: why would clothes get caught in my dryer & start smelling burnt?
there must be problum with the felt change it
Posted on Feb 18, 2009
  • 62 Answers
SOURCE: My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Posted on Jul 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My Frigidaire Dryer model # FDE336RES1 was running
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 17, 2009
heatman101
  • 43501 Answers
SOURCE: frigidaire made a nosie then followed a smell.
Sounds to me like your motor is bad.
They will make a bad noise and then go up in smoke when the bearings go out and the windings short out...I would check for power to the motor and if there is power going to the motor and the motor does not run then you have confirmed what I think the problem is.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 18, 2009
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
May 21, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fishy smell coming from breaker box and dryer tripping breaker
The problem is probably the breaker box. The fishy smell can be caused by the plastic housing melting so this needs looking at.
Dec 21, 2012 | Frigidaire Electric Dryer
Dead fish smell
Try putting in pie pans filled with loose coffee grounds for a couple of days. Might take a while to permeate the refrigerator. Then clean with vinegar and leave dish of vinegar in there.
Apr 29, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
SQD26VL side-by-side has a fishy odor. Where is drip pan?
The drip pan is outside the fridge I believe, sitting in the back panel.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
My fridge smells fishy. It is perfectly clean and i have not had fish in there.
Bacteria will cause the smell. Make sure it is cold and put a box of baking soda open inside the fridge. It will absorb the odors. They sell baking soda with a mesh side specifically for your fridge.
Jun 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Odor / smell
If it is putrid meat
Look under your car for roadkill , or for that matter under the hood
Has an animal crawled into the muffler area for warmth and has either died there or been killed when you started up
If it is a fishy smell
I dont suppose that you have upset someone and they have tied a piece of fish to the muffler
A very old way of extracting revenge
Jul 05, 2009 | Chrysler PT Cruiser Cars & Trucks
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Fishy, steam odor coming from AC vents
Forget the radiator tank. Your AC 'Condensate drain' hose is plugged up. This is a common problem. If you know where the hose comes out under the car you can ( carefully ) push a wire up it. If you're lucky it's plugged near the end by a mud-dauber wasp. If not, take it to your dealer and see if you can persuade the write-up guy to show you where the drain outlet is as a gesture of good faith. If they insist on charging you money, consider that when you buy your next car...
Dec 30, 2008 | 1994 Lincoln Town Car
Frigidaire Chest Freezer Door Insulation smells like fish
might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
Oct 08, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire  Electric Dryer Logo
70 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
