Question about Electrical Supplies
Hi, I have a 25 mile range Parmak solar pak 6 fence charger. When I test the lines it reads .02 and I noticed that the energizer unit itself is energized. I tested the unit and it reads between 3.8 to 4.6. When I disconnect the hot wire from the fence, the unit is no longer energized. When I test the voltage straight from the posts, it reads 8.1. Is it also supposed to read the voltage by just touching the hot wire post without a ground?
    Sergeant:
  • 315 Answers
Any point you measure has to be compared to a reference. This can not be accomplished by just touching one spot....it must be compared to something. Do I make sense the way I explain this?
Hope this helps! Good luck
Posted on Dec 30, 2013
3 Suggested Answers
  • 76 Answers
SOURCE: I just bought a Parmak 6 volt solar electric fence
I WOULD THINK SO BUT THE BLACK MAT BE THE POS. AND YOU MAY BURN UP THE CHARGER IF HOOKED UP WRONG BUT OTHER THEN THAT YOU HAVE GOT I THINK
Posted on Jun 24, 2009
ahsalex01
SOURCE: I bought a Parmak Solar Pak 6. I wanted to use it
The Parmak Solar 6, though they claim is more, is less then 1/2 a joule of output power. Even if you maintain enough voltage to shock the bears there is not enough power behind that voltage to hurt them. In our experience, you need at least 5 joules to really stop bears.
Posted on Jul 27, 2012
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
No charge, is it battery or solar panel, how do I tell
if the unit is not produceing a charge during daylight then it is the unit. the DF-SP-LI will produce full power under sunlight alone. test the unit with the fence unhooked.
Jun 01, 2012 | Parmak Solar Fence Charger
C lightening hit my mark 7 fence charger is it worth repairing
If lightning hit the unit itself then it more then likely destroyed any electrical components inside the unit. I would say get a new one and dont even bother repairing it.
Apr 16, 2011 | Parmak Solar Fence Charger
Need battery
We have one of these, it's great.
See these links:
http://www.parmakusa.com/Battery_Maint.htm
http://www.parmakusa.com/service.htm
I would try removing the battery and charging it with a proper low-amperage charger (1 amp). Your battery will either be 6 volt or 12 volt, just be sure the charger matches.
Also check the ground rod and all wiring connections.
May 13, 2010 | Parmak Solar Fence Charger
when you touch the wire, you are probably wearing shoes, which ground you,
touching it barefoot or kneeling on bare knees should provide a bit more jolt.
take your multi-meter, shove one probe in the ground and touch the wire with the other and you should get a nice reading
May 08, 2010 | Parmak Solar Fence Charger
Installing instructions
You can download and print your PARMAK manual here:
http://www.agfence.com/fence/Assets/documentation/parmak/InstallationManual.pdf
Dec 19, 2009 | Parmak Solar Fence Charger
We have 2.2 miles of fence,the charger is good for 30 miles.We have a 8 ft ground rod by the charger. the fence is a continues loop. positive wire to fence, negative to ground. meter on the charger says it...
You have got to make sure there are no weeds or brush at all touching the hot wire. Nothing can touch it or it pulls the voltage level way down. Do a full inspection of line.
Oct 02, 2009 | Parmak Solar Fence Charger
I can hear the charger clicking but the meter is not reading
check voltage coming from unit with a FENCE
voltmeter if voltage is in the5to6000v range probabley the meter is faulty youdoit.com
Jul 25, 2009 | Parmak Solar Fence Charger
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Electrical Supplies Logo
97 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
