Question about Kenwood DV-2070
Problem started when the face wouldn't open, although you can hear the motor. I manually opened the face and I could operate the unit that way. It worked for about a day and then the unit stopped reading DVDs. Now it will only play CDs. Any suggestions? I called Kenwood, they want $35 to diagnoise and $60 an hour after that.
  • 36 Answers
There are 2 seperate issues there, the flap wont open because either a cog has been damaged or if it used a belt it will be broken or worn, I am basing this on the fact that the motor is whirring away. The fact that it doesn't read a DVD but ok with a CD is more likely that the laser assembly may not be focusing properly, a DVD carried more information and it is compacted more than a CD, try cleaning the lens with a cotton bud slightly wet with ethanol, and clean the wormwheel and rod that the laser assembly travel on, try not to touch the assembly with your bare hands as it is electrstatically sensitive, unless you earth yourself. If all that doesn't work there is a chance the laser is wearing....Phil
Posted on May 19, 2009
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Power window won't go down but you can here the motor running in the door
You can remove the door handles and power window switches and the screws in the door pad and push up on the pad and it will come out of the track and then you can see the motor and replace the part yourself. Hope this helps.
May 05, 2017 | Chevrolet Camaro Cars & Trucks
Our Hoover (3535d) dryer tumbler does not want to spin although you can hear the motor starting. The load does not appear to matter. There is no sign of belt slipping. Can the problem be due to the start...
If you hear the motor starting then it normally wouldn't be the start capacitor. It is when it doesn't start that you suspect the capacitor.
If your motor is turning and belt is NOT slipping then your drum should be turning! Those things do tell you that your electronic (control board and timer) are good, but you are wrong about either the motor or the belt!
Jul 03, 2011 | Hoover Dryers
I have the driver CD but the CD slot of my computer wouldn't open up for me to insert the CD. Cannot find the right driver to download from the website. Please show me the link.
There is a small hole on the front of the CD face. You can insert a paperclip to pop it open. Why it won't open is a different problem and would probably require a new drive.
May 17, 2011 | Computers & Internet
Humming, but no spinning
It could be the capacitor which kick starts the motor.
they are relatively cheap to replace.
Ash
Oct 22, 2009 | Frigidaire Dryers
Door opener looses power
Motor has a thermal sensor if it gets too hot it trips the sensor till it cools down. Motor may be going bad, or door may have gottin to heavy ( spring loose tension over time) disconnect door from operator. You should be able to raise it easily manually.
Oct 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 1995 Sear garage door opener that stopped working
The trolley (the part that moves back and forth and is connected to your door) of your opener is most likely jammed against the bolt just in front of the motor unit. You can remove the bolt or loosen the chain until your unit will run. Once the door is closed find the 'up limit' on the side of the motor unit and turn it about 3 turns in the opposite direction of the arrow printed on the cover. Now replace the bolt or tighten the chain. Whichever you first did.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pasenger side head light will not retract or open. can hear motor operating
perhaps something is obstruting it. Can you open manually? IF so, open, look at it closely and start with wd to loosen some of the mechanism. then, with assistance, have someone turn on lights and you can feel the motion and try to isolate it. If the motor is working, something else is stopping it from opening. Also, motors make noise sometimes, even when they aren't working correctly. Let's see where that takes you.
May 05, 2009 | Mercury Capri Cars & Trucks
I have a CDX-M8815X unit only works with remote commander
The problem is the ribbon cable,the one connects the face to the main board,if you live in USA you can order it from pacparts.com or sony.com.
For replace it you will need to open the unit and open the face by moving manually the gears,then remove the side screws of the face and remove face,then remove the cd mech. you will see the ribbon connector.Just replaced and put everthing back togheter.
Good luck
Nov 30, 2008 | Sony CDX-M8815X CD/Receiver/MP3 System
Unit powers down when motorized face opens
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
Apr 11, 2007 | Pioneer DEH-P8500MP CD Player
Kenwood DV-2070 Logo
29 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
