Question about 2K Sports NBA 2K14
When trying to play my career screen shows i don't have internet connection when i do
Xbox one next gen
Why dose my profile keep signing me out when putting on games and when trying to play some games
Sometimes it may depend on the connectivity of the level your internet. A while ago I had a lot of problems with internet and like you, my games often crashed.
The easiest thing is to check your connection and make sure you are getting a strong signal.
On Xbox 360 to check your connection just follow this link:
Troubleshoot Xbox 360 connection to Xbox Live
While it's a lot to read it will help you in the long run.
To check your speed on Xbox Live go here
Slow experience on Xbox Live (for Xbox One)
You can also check out to see if Xbox Live may be the problem. By going to this link.
Xbox Live Status
The next thing, try replacing your router, when I bought my new router my problems stopped. You can also upgrade to a newer modem to DOCSIS 3.0. This of course depends on your internet speed. If you are below 20mbs I wouldn't worry about upgrading just yet. But upgrading never hurts. However, if you are trying to get 50mbs or more DOCSIS 2.0 bottlenecks. While I am no expert on modems. I think the DOCSIS 2.0 modem bottlenecks around 38mbs.
To Check your speed on the internet, this is the site most people go to.
Speedtest net by Ookla The Global Broadband Speed Test
Use whichever server you wish. I usually do multiple ones to see how it differs.
Jan 13, 2015 | Microsoft (X-Box) P5F-00001 Xbox 360...
Cant connect to xbox live with dlink 635
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Jul 11, 2012 | Computers & Internet
HOW DO I CONNECT MY XBOX 360 TO INTERNET THRU MY DIAL UP MODEM?
Hello Brian
Using Xbox Live on Dial up Modem would be a big pain, still listing the steps for you, hope you have a stable connection to successfully connect
Required Items
- Windows ME, XP, Vista
- PC with dial-up connection working
- Ethernet Cable (RJ45) cable or CROSSOVER CABLE
- Xbox 360
Let's Get Started
1. First connect the Xbox 360 and the PC using the Ethernet cable.
2. Double Click your Dial-up Network connection and wait for it to connect.
3. Choose "Start Menu" and then choose "Settings" then "Control Panel".
4. Select "Network and Internet Connections".
5. Open the "Network Setup Wizard" and then press "Next".
6. On the next screen Ignore the checklist and press "Next" again.
7. Select "This Computer connects directly to the internet." and press "Next".
8. Now Select your dial-up internet connection as your default connection to the Internet and press "Next".
9. Select "Local Area Connection" as your private connection and leave all other areas untouched and click "Next".
10. On the Workgroup screen leave all settings alone and click the "Next" button.
11. On the next screen Turn on "File and Printer Sharing" if you want to share your files, mp3's, divx files with your xbox 360 and click "Next".
12. Now review the settings and click "Next" to apply the changes.
13. You do not need to run the Network Setup Wizard on any other pc's so just click "Next" and continue.
Now that the wizard has completed you may need to reboot your PC and dial your internet connection again.
Xbox 360 Setup
Now we have configured your PC to share its internet connection and files to your Xbox 360 we need to configure the Xbox 360.
(Steps for old Xbox 360 Dashboard, in case you do not have NXE dashboard)
1. Go to the "Xbox 360 Dashboard".
2. Select the "System" Blade.
3. Select the "Network Settings" Option
4. Now choose "Test Xbox LIVE Connection".
Your Xbox 360 will now attempt to contact your home network. It will check to make sure it can assign itself a IP ADDRESS from your PC and then it will also check DNS server information and XBOX LIVE.
let me know if this helps
Nov 25, 2009 | Microsoft Xbox 360 Console
Requires an xbox live membership with permission to play live
You shouldn't need the parental controls changed to log onto Xbox Live. However, since you switched computers make sure that your Xbox is getting connection to the internet correctly. You can 'Test Connection' in the settings tab of the Xbox home screen.
If you are getting the internet connection correctly and logging in with your normal Gamertag, you should have no problems.
Jul 03, 2009 | Microsoft Xbox 360 Console
Screen Problem! Need Serious Help!!
MS recommended and a repair is wise if this is a constant issue. Some people tackle this problem by opening up their Xbox 360 and finding the problem themselves. Those who do report a small magnet that holds the disc in place, loose or not connected. They simply glue this back on; however, opening the Xbox 360 renders the warranty invalid, therefore future repairs may be denied and a fee may be placed.
Dec 20, 2008 | Microsoft Xbox 360 Console
Change NAT to open
I don't have your Internet connection details or OS
so we'll start from the beginning:
1.Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your time zone. On step 3 this is important; select your Internet connection type. On the 4th step leave the Address Mode in Dynamic and enter the username and password supplied to you.
Once you have configured your Router to work with your Internet connection type, you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/r...x_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mentioned on this page is, for each port you forward under the box that says "IP Address", don’t put the IP address of your computer, you put in the new IP address of the Xbox 360 which was one of the 5 that was generated from that link in step 2. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start> run> type in ‘cmd’ then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Feb 23, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Guitar hero 3 for xbox 360
something is wrong with your disc you can either try to clean it with a damp cloth or find a store near you that cleans discs for you
Jan 04, 2008 | Microsoft Xbox 360 Console
2K Sports NBA 2K14 Logo
481 people viewed this question
Top 2K Sports Video Game Consoles & Games Experts
James Wishart
Are you a 2K Sports Video Game Console and Game Expert? Answer questions, earn points and help others
