Question about Samsung Galaxy Ace GT-S5830
Yellow triangle when turning fone on
Even when fone is on charge the warning sign for battery is showing
What does a yellow exclamation point inside a triangle warning sign mean. Now check engine light just came on.
The yellow triangle with an exclamation mark will typically be accompanied by a message explaining what's gone wrong. Hopefully it will be self-explanatory - such as a low reservoir for the windscreen washer system.
Dec 28, 2017 | Cars & Trucks
What does a bright orange triangle( with a ! in the middle of it),mean when tablet will not on ?
Thread: Android bot laying down with exclamation mark - Asus ...
www.transformerforums.com > ... > Asus Transformer (TF101) Help
Apr 7, 2012 - 10 posts - ‎5 authors
Hello: With the tablet powered off I press down "- volume button" and ... Guys - you can only do a cold boot or factory reset through the .... No worries I've sounded grumpy occasionally myself - even big, bright, yellow, grinning me ... dead android with redtriangle ... what does an android avatar laid out mean.
Warning triangle and thermometer on charge s... ' Samsung Galaxy S ...
forum.xda-developers.com/.../warning-triangle-thermometer-charge-t15...
Apr 13, 2012 - 5 posts - ‎4 authors
I also can't turn the phone on unless I go to Recovery and reboot the system that way.Does anyone know what this means? Thanks.
Jan 19, 2016 | Tablets & eReaders
How to get rid of yellow engine symbol on dashboard?
Will need to have it daignosed by a professional and perform repair that is needed.
The "check engine" light is on because of a problem that the computer has sensed within the sensors of a faulty circuit.
The triangle is on because the problem is also effecting other modules within the vehicle.
Perform diagnostics to determine problem and repair problem..
Feb 22, 2015 | 2001 Audi A4 1.6
I have toyota prius 2008 suddenly start showing little red triangle and green car display on the battery diagram gone red from green please any body knows about it..
I had the same problem, Check the inverter coolant pump.
Most probably , the pump must be not working.
How to check the coolant pump?
Closer to the inverter , there is clear plastic bottle filled with red colour solution.
Now open the lid while on start and check whether the water is moving.
If the water is not moving , then definitly the solution is to replace the coolant water pump.
I hope you can correct it.
good luck.
Trishan Sri Lanka.
Feb 14, 2013 | 2008 Toyota Prius
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
When turning left, a yellow warning sign comes on dashboard on my 2000 Audi A4. It has a tringle and circular arrow around it. It flashes, and accelarator turns off. Any ideas what this could be?
The yellow triangle is a warning that a sensor has detected a problem. You might check that all of the fluids are full. especially the oil. Going around corners shift the fluids from one position to another and then the sensor thinks that the fluid is low therefor giving a false reading.
May 22, 2012 | Audi A4 Cars & Trucks
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Kyocera Finecam S5R digital "flash close"
You forgot to open the shooting flash on the top of camera
Nov 24, 2007 | Kyocera Finecam S5R Digital Camera
Samsung Galaxy Ace GT-S5830 Logo
29 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
