Question about Sony Playstation 3 (PS3) Console
No video but sound
I borrowed a ps3 from a friend and when i hooked it up with the rca cables i can hear the sound but no video. i have an hdmi cable with it but can not use it with my tv (older hd rear progection big screen) not sure if he had it hooked up hd at his place. any thoughs?
    Problem Solver:
  • 11 Answers
Go to another tv
Posted on May 24, 2009
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
No picture thru hdmi but picture thru RCA plugs
I had this exact same problem, or rather my friend did after I borrowed his PS3. You see when I borrowed it, the console configured the HD output to work with my TV, If this happened to you, there is a fix, With the HD cable connected, turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Is hdmi cable the only cable hook up to ps3 to t v
hdmi resolution of 1080p (dots on the screen) which is 3X better then composite video 480i with RCA audio
May 16, 2009 | Sony Playstation 3 (PS3) Console
Console starts up and I can hear but shows no picture.
make sure video cable is plugged in all the way on back of ps3. the a/v cable is little tricky. it looks like its plugged all the way but its not. also if doesnt work, if u have hdmi cable use it then go to display settings, then connetions. set it up as av cable connection then it will ask about audio - av rca connetions. and save. now its set up as av cables and then when u use hdmi it will automatically set up hdmi.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
I recently had my ps3 hooked up to the tv via the hdmi cable. Now i have taken it to my friends who does not have have hdmi so i connecting the three cables to the tv but have no picture or sound, why and...
Easy Solution,
Make sure your PS3 is connect and powered OFF.
Hold down your power button for 5-6 seconds until you hear the second beep.
That's it! Your video settings have been reset.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will work on the rca hookups but not on the hdmi hookups
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
PS3 no picture on screen. Borrowed Unit from a friend.
If the TV was originally set up on an HDTV via HDMI cables you'll have to reset the video/audio outputs on the PS3. When you turn the PS3 on hold your finger down on the button until it beeps a second time, then remove your finger and let the console restart. That should reset the PS3's video output.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
