Question about Virgin Pulse VP14 (14 Channels) 2-Way Radio
Manual for the pulse vp14 2 way radio - Virgin Pulse VP14 (14 Channels) 2-Way Radio
My aftermarket radio is not working in my 2005 Chevy equinox. Do anyone know why? It's a new radio and all of the wires are connected properly. The chimes stopped working as well. Fuse are new as well
The chimes work through the factory radio , come out driver door speaker . There is a interface module you need to hook up on GM vehicles so aftermarket radios will work . With these newer vehicles your better off taking to someone or place that does this on a daily basis . Does it start an run ? If it does i'm surprised , factory radio is also hooked to the vehicle serial data network , class 2 . Suggest you google that .
Battery positive voltage is provided to the radio from the Radio (15A) fuse in the fuse block. The radio is grounded through a braided cable case ground. The radio is enabled/disabled by Class 2 messages from the body control module (BCM). The entertainment system on this vehicle is configured with a base and uplevel system. The base and uplevel systems contain a radio, antenna, speakers, and on some vehicles an audio amplifier.
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings. The BCM receives audible warning requests via the class 2 serial data line or the controller area network (CAN) data line. If the BCM receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Mar 15, 2017 | Cars & Trucks
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
May 13, 2016 | 2009 Chevrolet Cobalt
Pulse noise
Not sure what you mean. Can you give more info?
Feb 11, 2014 | Midland 1001Z 40-Channels Base CB Radio
When the car and amp are on but the radio is off the sub makes a pulse sound
The amp is generating output even if the radio is off. Your sub probably is a high compliance unit so the cone has a lot of free movement which creates the pulsing sound you hear
Mar 07, 2013 | Car Audio & Video
Unlocking radio in Mercedes Smart Car Pulse
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Mercedes service centre and get them to enter this code for you.
Jan 12, 2013 | Car Audio & Video
I have a TRC - 432 base station, I keep getting a pulsing sound in the audio and when pulsing the channel display dims with the pulse. any help in what could be wrong? the radio has not been turned up at...
you may want to take it to a tech because it requires changing components in the receive circuit and the audio circuit .As long as it has never been tuned the tech should have no major problem repairing it.
Jan 04, 2011 | Radio Shack Radio Communications
1985 Chevy Astro...And yet another question...lol...there was a yellow wire stuck in with the fuse for the radio...is it supposed to be there? Is it the ground? HELP!! Thank you in advance
Yes, this is the pulse connector, it feeds the radio timed pulses of power in order that iyt may retain the correct time and your station choices.
Sep 09, 2009 | 1985 Chevrolet Astro
Virgin Pulse model VP-07 CD clock radio
1. To set the clock to leave the unit in standby mode. (Plug in the AC cord to a wall outlet without switching unit on). 2. Press SET button for about five seconds until AM--12:00-- stops flashing. 3. Press down TUNING button to adjust hour, and up TUNING button to adjust minute. 4. Press SET button to confirm time set.
Sep 11, 2007 | Virgin Pulse VP-07 Clock Radio
Virgin Pulse VP-14 manual
http://safemanuals.com/ if i helped you at all would you please let me know by rateing my help. thank you kathy
Aug 21, 2007 | Virgin Pulse VP14 (14 Channels) 2-Way...
Virgin Pulse VP14 (14 Channels) 2-Way Radio Logo
44 people viewed this question
Top Virgin Pulse Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Virgin Pulse Radio Communication Expert? Answer questions, earn points and help others
