I need replacement ear ts
Lost ear bud soft tip, rendering the device useless. I need to buy new tips. Where can I get them?
  • Audio Player... Master
  • 5,158 Answers
This place might have them:
Posted on Jan 03, 2014
SOURCE: left bud not working properly
Same thing happened to me today, so i took out the mesh to see what was going on.  Like solution 1, the mesh was the problem and i removed it with tweezers but i couldnt help bending the mesh a little.  Its not that its a problem of the mesh touching the cone but that the adhesive that attached the mesh was covering the whole underside of the mesh along with some wax.  I removed the silicone adhesive with the tweezers and washed out the wax with some peroxide.  The trickiest part is getting the mesh back in.  I put one side of the mesh in with the small lip facing down, slightly bent it so it made a bump on the top of the mesh and maintained its convex shape and then squeezed in the other side with trying to keep the lip in while doing so.  Took me a few tries but after you get it in push the edges in so they don,t come out again and file down the edges if there are any sharp pieces of the mesh protruding.  And your done.  Solved my problem, hope it works for you.
Posted on Feb 26, 2009
  • 20 Answers
SOURCE: I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
Posted on Mar 19, 2009
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
Poor contact with ear bud jack. Can this be fixed?
You can try to clean the headphone jack with rubbing alcohol. Use a q-tip. Just moisten q-tip as you don't want lots of liquid running into your device though the alcohol will dry quickly.
If it is a loose connection, you may have to open your device and need soldering skills to fix it. Try cleaning the jack first.
Feb 22, 2016 | Eclipse T180 4gb 1.8" Touch Screen Video...
Eartip not staying in
Depending on the manufacturer of your headphones you may be able to buy new tips that will stay in your ear better. Or you'll need to look into headphones that have this feature, or you'll need headphones that go over the ear. Personally, my ears don't work we'll for any in ear types of headphones, almost all fall out. I have a pair of Shure's that have foam tips that stay in better than all the others.
Nov 09, 2013 | Plantronics Radio Communications
Should you clean out your ears with Q-Tips (cotton buds)? I always thought it was a good idea but someone told me you should just leave ears alone.
Although people like to use Q-tips to clean out their ear wax, they should just leave it alone as it's the ear's mechanism for self-cleaning. If you have a build up of wax you can see your doctor but otherwise you can just leave your ears to clean themselves.
Jan 10, 2013 | Health & Beauty
How do I replace ear buds on electronics 520?
There are no replacement earbuds for Plantronics Voyager 520. You would need to replace the headset if the earbuds are making it uncomfortable enough that the headset is unusable. Link to Headsets Direct Bluetooth Headsets is included below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Jun 28, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Cable is obviously broken inside earpiece, on one side only
Take off the rubber tip and with gentle but firm pressure slowly bend the tip between thumb and forefinger towards you. The cap and tips are not glued and are held in place by two clips which break easily so be careful! Hold the bud upright with the Klipsch logos facing away from you and bend the tip towards you. They actually separate really easily. When finished they just clip back into place.
May 05, 2011 | Klipsch Image S4 Headphones
I have lost sound in the left earpiece. Are they history?
i think i might have fixed the same problem i had with mine. I took off the gel cover thing and put a tack or saefty pin in the hole of the gray speaker cover. pull the cover out and clean all the ear wax off the speaker part. it works great now after i cleared the ear wax from the sound hole.
Mar 23, 2010 | Bose in-ear headphones - Black with...
Apr 10, 2009 | Sennheiser CX 300 Consumer Headphones
78 people viewed this question
 Grubhead
Grubhead
