Question about LG Washing Machines
Remove LG 5101 pulsator
Pulsator making noise
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
Tip
All codes Secrets for LG Cell phone
<span> <span>LG all models test mode: Type 2945#*# on the main screen.<br />2945*#01*# Secret menu for LG<br />IMEI (ALL): *#06#<br />IMEI and SW (LG 510): *#07#<br />Software version (LG B1200): *8375#<br />Recount cheksum (LG B1200): *6861#<br />Factory test (B1200): #PWR 668<br />Simlock menu (LG B1200): 1945#*5101#<br />Simlock menu (LG 510W, 5200): 2945#*5101#<br />Simlock menu (LG 7020, 7010): 2945#*70001#<br />Simlock menu (LG 500, 600): 2947#*<br />LG-U81XX SPECIAL CODES</span> <span></span>Code to read phone version :<br /><span><span>- Phone without SIM<br />- Enter 277634#*# or 47328545454#<br />- Select 'SW Ver.info'<br /> Code to reset phone :- Phone without SIM<br />- Enter 277634#*# or 47328545454#<br />- Select 'Factory Reset'<br /> Code to enter UNLOCK MENU :- Phone wit SIM inside<br />- Enter 2945#*88110#<br />Test Menu 8330 : 637664#*#<br />Test Menu 8180 V10a: 49857465454#<br />Test Menu 8180 V11a: 492662464663#<br />Test Menu 8130-8138: 47328545454#<br />Test Menu 8110-8120: 277634#*#</span> <p><br /></span></span> <span><span><span><br /></span></span></span>
on Jan 11, 2011 | Cell Phones
Defy Laundromaid 1300 making grinding noise while washing,how do i remove pulsator to see if there is something in it
if the grinding noise is more pronounced at spin cycle , it could be the drum it self, if the grinding noise is there constantly, could be the bearing to the drum. front loader. easy to fix, let me know..
Apr 14, 2014 | Washing Machines
There's a clunking noise coming out of the lower rad and it's making the hose pulsate. There is no pressure on no hose No heat
is cooling system full of anifreeze..if not it has an air lock in it that clunks like a steam radiator in an old building...need to check level and maybe replace thermostat..
Feb 10, 2013 | Cars & Trucks
How to remove pulsator from machine
Hi raju_zade,
Quite easy. I take it you are referring to a top loading L.G washing Machine.
- Switch of the appliance at the wall, and open the lid.
- In the center of the pulsator is a small sieve cap, open it's latch
- Inside it, in the middle is a small screw, unscrew it
- Now simply pull the pulsator from the sides, this is sometimes difficult to accomplish due to washing powder buildup, but persist and it will eventually pull free.
I hope this has helped.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | LG Washing Machines
No water , when running, loud pulsating noise
Usally when there is no water comming in it is the water inlet valve. First turn selector swith to see if it is only hot or cold water that is the problem. Take the hoses off the back of the washer and make sure that when you turn the water on that there is lots of water pressure comming out of the hoses. If ok. its probably the water inlet valve. There are two screws holding the valve from the back. Access the valve. Remove the fill hose from the valve. Remove the four wires off the valve and put on the new valve. Reinstall fill hose and install valve with two self taping screws you took out. Put your hoses back on and your ready to go.
Dec 22, 2009 | Kenmore Washing Machines
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
LG top loader slapping noise in wash cycle
Its not the usual problems found on Lg machines. sounds like you have possibly one or more coins being picked up underneath the pulsator. To check, remove pulsator with screwdriver and check .Very possibly you have a bra cup spring caught between the two drums which make an akward sound.
Jan 27, 2009 | Washing Machines
Recall
I had the 5101 I just sent it back last week to manufacturer,most of oil filled heaters make a noise as the oil heats up. The 5101 had a black control panel &black wheels & foot rest. Hope i was of some help. If u have more ? let me know. slinger5@localnet.com
Jan 26, 2008 | Lakewood 2727 Heater
Washing Machines Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
