Stirling xqb100-y1066s will not spin error 4 comes up
Will not spin it is only 3 mouth old error 4 comes up
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Have you cleaned the filter
Posted on Dec 30, 2013
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
Cfds50 bleeps on cd load
Do you mean like a bleep to replace the 4-letter words coming from your mouth when the player gives you a No Disc error? Yes. Quite normal. Toss it and get a real boom box.
Jun 20, 2016 | Sony CFDS03CP CassetteCD Boombox
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
Whirlpool duet 4.0 washer 3 weeks old suddenly beeps 3 times after start button will not run
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Gemmy Dean Martin Mouth doesn't move. I took the head off by removing the 4 staples and can see the internal parts. There are 3 phillips head screws at the base of the head and 2 holding the plastic post...
Remove the staples to loosen the mechanism from the neck.
Remove the two screws holding the post to the mechanism base with a small Phillips screwdriver. Push the mechanism mouth out as much as you can to reveal the mouth post base. Using a hairdryer, heat up the mouth post glue and pull gently to remove the mouth bottom. Pull the mechanism out. Take off the spring. Replace the string with similar string. I would also recommend buying a new motor on ebay for $3 from China. You can get him singing again.
Feb 16, 2010 | Gemmy Toys
Kenmore f21 error
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jun 14, 2009 | Kenmore 46462 Front Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
