Question about Toys
One of my black spider xt helicopters lights but does not respond to controller. The controller works with another black spider xt helicopter.
3 Suggested Answers
  • 35 Answers
SOURCE: have helicopter charged new batteries
Hello Susan,
What you need to do is to gently pull the cockpit housing off the post at the bottom rear and remove it from the machine. You can now access those connector plugs much easier along with noting where the trim screw is located.
Please note that the battery pack has a female connector while both your charger and the lead to the electric motor have male ends. Those male ends have two small pins within the connector and you need to get them oriented correctly with the round holes within the female connector.
Once you have established this, a dab of finger nail polish on the top side of each connector will make it easier to orient the plugs for charging the battery, or connecting the battery to the motor leads in the future.
Make sure to charge the battery for at least three hours, Do Not Overcharge.
Posted on Jan 18, 2011
tvking1
SOURCE: Bottom propellers won't spin on my black spider xt
Had the exact same problem wire to gear was not welded properly reattach and done.
Posted on Dec 13, 2012
My Air Hog Black Ops helicopter blades do not spin. It is charged as lights on helicopter and controller work. I have tried setting controller to all 3 channels with no luck. Any ideas?
check over the helicopter first then hand controller
heli
could be the receiver chip or pick up on the helicopter
motor issue ?
didnt think it was direct drive .might be
have to chase a broken wire connection or other
if cogs or belts are used ..stripped or jammed or other
receiver
toast
Jun 18, 2016 | Air Hogs Havoc Heli Helicopters
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
How to fix a syma helicopter if it is not responding
My helicopter used to do that too I called the company and told them my problem they said to change the batteries in the helicopter in a week they delivered the batteries and my helicopter was working agaim
Apr 21, 2014 | SYMA Toys industrial New Syma S107 Radio...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Why wont my RC helicopter respond to the controller
The Helicopter channel/frequency may need changing to match the channel/frequency on the transmitter.
OR change the transmitter channel/frequency to suit the helicopter.
Feb 06, 2013 | Toys
Where can i get a copy of instructions for black spider xt indoor helicopter
You have to remove the cover on the bottom of the remote controller and take out the cord. Then take the cord and plug the end into the helicopter right above the on/off switch.
Dec 28, 2012 | Sky Toys
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
The helicopter will not synchronize and I can't get it to communicate with the remote.
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
