Question about GMC 2003 Envoy SLE
2003 gmc envoy: shifter will not click into park, key stuck in ignition and won't go into off position to take out. How to fix?
Gear shift will go into park, but will not click into place. There fore the key will not go into off position to be able to remove key from ignition
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
Sounds like the shift cable needs adjusting on the transmission. It will be on the driver's side, heavy black cable sheath with an adjuster. Adjust it a few turn in one direction then check to see if it gets better or worse. Fine tune as needed
Posted on Dec 30, 2013
How to remove my Keys from 2003 envoy they are stuck
Ignition Lock Cylinder Control Actuator
If the vehicle is equipped with a floor mounted console gear shifter, it has a ignition lock cylinder control actuator system in the steering column as an added safety feature. The ignition lock cylinder control actuators purpose is to prevent the steering wheel from being locked when the transmission is in gear and the vehicle may still be moving. The column ignition lock system consists of a ignition lock cylinder control acutator, and a park position switch that is located in the A/T shift lock control switch. The ignition lock cylinder control acutator contains a pin that is spring loaded out to mechanically prevent the ignition key cylinder from being turned to the lock position when vehicle transmission is not in the Park position. If vehicle power is lost, and/or the transmission is not in the Park position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column. GM has had some problems with this , If you have the console shifter there is a micro switch that when put into park a linkage pushes on this micro switch closing the circuit to ignition lock cylinder control actuator allowing you to remove your key ! These linkages fall out causing this problem ,an have electrical wiring problems as well ! I fixed a 2006 Chevy cobalt that had this same problem by getting a used shifter assembly at the auto salvage year ! cost $20.00 . There mite be a access hole under the bottom of the steering column with a release button up inside !
Apr 17, 2015 | 2003 GMC Envoy
Gear shift stuck in park
Could be the brake switch, or the shift lock solenoid. You may be able to take the shifter out of park by unlocking the key switch but not turning the switch to the on position. The components would need to be tested.
Aug 05, 2014 | 2005 GMC Envoy Xl
2005 GMC ENVOY Gear Shifter won't move,why and how do I fix the problem?
I am assuming the shifter will not move out of Park (you don't mention it). The shift interlock is not working. Thing you can do is turn ignition key little, but just before ignition comes on, and try to move shifter to N. At this stage you can start the engine and shift to D. This is a temporary solution to allow you drive the vehicle to a repair facility. If you are successful, it is the interlock solenoid that needs to be checked out.
May 24, 2014 | 1997 GMC Sierra
Problem with the actuater.either needed to be adjusted or replaced.Actuater is visible and located on the gearbox it self .
Dec 29, 2013 | GMC 2003 Envoy SLE
I have a 2003 Chevy blazer xtreme 4.3 v6 automatic transmission and its giving me some issues with the console shifter and ignition system! Every other time I put the blazer in park and try to take the key...
Fixing stuck key in your gmc envoy same as a blazer !
May 08, 2017 | Cars & Trucks
2003 crown victoria won't come out of park
Had a similar problem. Solved it two ways first place key in the 3 position move gear to N then start and it will shift easily. Second solution check brake light fuse, it is probably blown replace it and gears will shift OK.
Jul 01, 2012 | 2003 Ford Crown Victoria
Ignition switch won't release key when it is put in park. But when I removed switch and key tumbler, the key tumbler/cylinder releases key. Why won't the key release when it is in park?
Most newer models have a safety feature called
shift interlock. This prevents the key from being turned back
to the lock position if you forget to place the gear selector in park.
Depending on the model,
If it uses a cable, it may be sticking or needs adjusting.
If it uses an electrical solenoid. may be blown fuse or park switch.
Tap, shake, and pull up on the shifter and make sure it's in park.
May 25, 2012 | 1993 Jeep Grand Cherokee
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
Aug 05, 2011 | 2005 Chevrolet Monte Carlo
Gear shifter is stuck and my envoy will not go fully into park to release the key
you can put it in park fro underneath the vehicle set park brake use jack & jackstands . sounds like you need a shift cable . fun to replace on that rigg
Sep 15, 2010 | 2002 GMC Envoy
I have a 2004 GMC Envoy XT with 4wd. I started to
sounds like you have a broken shifter cable.Go under the rig and shift the transmision manually.Put on the parking brake and on the drivers side of the trany should be the lever to move.Look for the broken part while you are there it will also help to locate the shift lever on the trany.
Jul 31, 2010 | 2004 GMC Envoy
GMC 2003 Envoy SLE Logo
174 people viewed this question
Top GMC Heating & Cooling Experts
gbob59
Lawrence Oravetz
Nicola Conroy
Are you a GMC Heating and Cooling Expert? Answer questions, earn points and help others
