Question about Acu-Rite Acurite Wireless Weather Thermometer 604
How to change time zone for meade rcw33w - Acu-Rite Acurite Wireless Weather Thermometer 604
The time zone is set to Pacific. I need to change to Mountain? Can this be done manually?
You should be able to change time zones manually. It would be helpful to have the manual handy to refer to the exact procedure.
Nov 10, 2015 | Honeywell Te923w Professional Wireless...
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
Oct 03, 2013 | H.H. Scott SCR120 Clock Radio
How do i change the time zone on my meade wireless weather thermoclock
Since you failed to give the model number I have included a few sources:
http://search.aol.com/aol/search?&s_qt=sb&q=meade+wireless+thermoclock+operator%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.meade.com/product_pages/weatherstations/weathertime/tm005x.php
Jan 20, 2013 | Audio Players & Recorders
How do I change out the main lense in my Polaris 60EQ-D
Your scope only has ONE main LENS in the front. You change magnification using the eyepieces. If the main lens is broken you must contact Meade here:
http://www.meade.com/support/index.html
Sep 29, 2010 | Meade Polaris 60EQ-D (36 x 60mm) Telescope
Mead lx6 model 2120. DRS will not get past the error message and when it does, the DEC and RA do not change when the tupe is moved in RA or DEC. Where can I get repairs done or mabe a schmatic for the...
This is a very old Meade SCT telescope. You can try contacting Meade customer service but I would doubt that they still have parts??
So, go to the Yahoo Groups LX200 forum and join and ask questions. Someone may have that model Meade SCT. Also there are people on the forum that can repair the circuits in the hand controller if something is blown.
Good luck.
Nov 04, 2009 | Meade Optics
Display on the autostar does not light up. The batteries are all changed, the power light comes on on the tripod, but the handset is dead.
Could be a cable problem. REVERSE the cable ends and try it again. Make sure the scope is always turned OFF before you plug or unplug a cable.
If this does not work then try a new cable. Meade sells these, or you can order a nice one from www.scopestuff.com . Not very expensive.
If after installing a NEW cable it still does not light up then time to buy another hand controller.
http://scopestuff.com/
Oct 31, 2009 | Meade 494 AutoStar Telescope Control Unit...
Changing the coordinates of the autostar for meade etx 125
What are you using as a reference for "LST time"? I assume you're aware
that stands for "Local Sidereal Time", and not Local Standard Time; some
folks have confused the two. Do you have another method to calculate
Sidereal time for your location?
When you set Date and Time in the Setup menu, you need to use the time
from the "clock on the wall" without any mental adjustments for Daylight
Saving or Time Zone; those settings are made elsewhere. From your
description of the problem, it sounds like you have a time offset,
especially if your Site location values are fairly accurate.
Whether you use Zip Code or City sometimes depends on where you live
with respect to a particular city. If you live several miles from the
nearest city, Zip Code may be best .
Dec 12, 2008 | Meade ETX-125PE (500 x 127mm) Telescope
Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
