Question about AviStart 5303 2-Way Security / Remote Start System
My car alarm siren will not go off
My father and I, have been working on installing this security system into my 2003 Toyota Highlander. We have everything connected and hooked ubut, the siren for the system will not go off and is not getting enough energy to make it sound as loud as it is supposed to be.
  • 29 Answers
You have a wiring issue, bad ground, incorrect relay, loose connection, faulty alarm horn... start with the alarm horn as they often fail due to debris build up and corrosion issues at the internal/external contacts... then check ground and make sure the circuit you added is on its own fuse and is not just jumped from another circuit... Post results or additional questions
Posted on Dec 30, 2013
  • usmwired Jan 03, 2014
    We finally figured it out, it was a loose connection.
How can I fix issue with Prestige asp57e remote start?
Return your Highlander to the local alarm shop and have them get the remote start working to your satisfaction.
Jan 28, 2016 | 2001 Toyota Highlander
My Toyota Highlander alarm keeps beeping at a few minutes to11am and 2pm without anyone touching it. I want it reset
Disconnect the battery ground for a couple of days.It will reset once you hook it back up.Otherwise,unplug the alarm from the system.
Apr 09, 2014 | 2003 Toyota Highlander
My viper alarm system when armed and disarmed there is no sound from the speaker
Either the system is in valet or, the chirps have been deleted or, the siren is broken.
If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.
Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
Mar 04, 2013 | 350 HV ESP Security System 350HV ESP
2003 Toyota Highlander Alarm Goes Off ?
problem could be in door central locking system or body ecm.let dealership check it out.
Jan 03, 2013 | 2003 Toyota Highlander
Won't let the starter kick in, replaced car battery helpk
dear kenny349
try to "give" 12 volts directly to the siren cables. if it works - siren ok, not - check relay, if it does not switch then propably your alarm isnt giving any kick to it. check or let check alarm unit.
hope it helps, feel free to contact me here under your topic for further help, pls before voting
kind regards
Feb 13, 2011 | Audiovox - AS-9903 - Six Tone Car Alarm...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
2003 dodge truck won't start -security light blinks on dash-everything is locked down
pretty vague, but you should find a button or a small switch under dash area drivers side probably. Turn the key on flip the switch or push the button, the alarm should then let you start the car. sounds like the siren isn't working
Aug 28, 2009 | Vehicle Parts & Accessories
Newly installed car alarm, LED in solid light n horn/siren blares
if you follow instruction properly than the alarm should work properly, Go over your wiring again 2-3 times make sure it make sense to you with the instructions. If it make sense than take the unit back and get another, can be faulty alarm.
Aug 26, 2009 | 2003 Toyota Corolla
CAR ALARM SET BUT NO SOUND
Try to panic the alarm if that does not work then your siren is probably bad also check the wiring leading to the siren to make sure it is connected......
Feb 15, 2009 | Viper Security and Remote Start System...
AviStart 5303 2-Way Security / Remote Start System Logo
177 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
