Will not spin
9kg top loader xqb100-y1066s will not spin error code e4 it clicks when you push start but then go to error 4 can you help we got the washer 3 mounths ago
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CEAQFjAC&url=http%3A%2F%2Fwww.stirlingappliances.com.au%2F_literature_842%2F9Kg_Top_Load_Washing_Machine&ei=WMDAUrn-NdGShQfg7ICwBw&usg=AFQjCNE3nkaGkSJGjbGHHlfFGmjl-ADIlg&sig2=o-WcC1F_-YpElGAi5e6FFw i assume youve checked manual if not above link will work,it suggests e4 to mean lid not closed,this could be a switch fault where the lid closes it must physically move a switch inside,or the wire to switch may have pulled out,either way if 3mths old ring for engineer,e2 is pump fault which would also stop machine from entering spin mode,
Posted on Dec 30, 2013
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
taran_2005
  • 10515 Answers
SOURCE: LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 03, 2009
  • 662 Answers
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
Posted on May 19, 2010
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Magic chef error E4
E4 indicates the washer failed to drain out after 4 minutes, after that time the code is set. Check and clean the drain filter first.
Jan 19, 2017 | Magic Chef Washing Machines
I have a top load samsung washer and for a while now it will give me a dc error code and won't spin all the water out of the clothes? Need help thank you
If your Samsung top loader is starting to spin, but stops after a minute or two, and starts to fill up with water again... and then after 3 times of doing this, it errors out with a DC error code, the problem could very well be with the support rods. The springs in these rods will get weak over time and allow the drum to become unbalanced during the spin cycle. Fortunately, the 4 support rods are very easy to take out and replace. And sometimes, they just need to be greased properly. I had a service technician replace my support rods, but he didn't grease the top and bottom bushings first, so my machine still wouldn't spin properly. After he left, I pull one of the support rods out, cleaned out the dried up grease where the support rods lock in, and applied a liberal amount of white lithium grease to the top and bottom bushings on the support rod. I then put it back in. I did the same for the 3 remaining support rods. Now the support rods were able to move very freely in their holders, which is necessary during the spin cycle. My machine now spins like it is supposed to and I don't get the re-fills and DC error code anymore. This webpage, http://www.appliancepartspros.com/samsung-assy-damper-owm-dc97-16350c-ap5623264.html , contains a video that shows you how to remove, inspect and grease your support rods properly. It is not hard to do, but can be a bit messy. Have gloves and/or cleaning rags handy. And if you do need new support rods, this place has them cheaper than you can get them from Samsung!!!!
Dec 14, 2015 | Samsung Washing Machines
My Cabrio top loader keeps giving me the error cods F 50. I have tried to reset it,uplug it,and still get the same error code.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Washer not spinning correctly
4E - WATER SUPPLY ERROR
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
May 04, 2009 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Troubleshooting Whirlpool Push to Start Mechanism for Washer
What kind of whirlpool do you have? is it a top loader or a frontloader. If it is a top loader is there water entering the washer? does it not agetate? Does it not Spin. If it does not wash or spin it is a possible bad lid switch close the lid. Do you hear a click? If you have no CLICK sound you have a bad lid switch.
Jan 22, 2009 | Whirlpool Push to Start Mechanism for...
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
