Question about Dishwashers
Maytag dishwasher manual
My maytag mjd 2005 has the light stuck on, half load, 3 hour delay, and rapid wash.it wont start and I can't unlock any of them.
gwshaw71
  • 83 Answers
SOURCE: maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
catriver
  • 878 Answers
SOURCE: Maytag diswasher problem
liberty, it sounds like your keypad is bad, here is your tech sheet for your dishwasher, it will give you detailed instructions for checking it out. Catriver
http://www.servicematters.com/maytag_library/docs/16026393.pdf
Posted on Jan 18, 2008
SOURCE: Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Posted on Dec 28, 2008
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Posted on Nov 01, 2009
SOURCE: Maytag mjd 2005 when started on normal gives a
I have the same problem but now on all cycles - to get it off normal and try the other ones, open the door, hold down the 'normal' button for three seconds, and then at least try the other settings temporarily.
Posted on Jul 30, 2010
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
My maytag dishwasher dosnt work. the delay light 2,4,6 lights just blinks. I would like to know the reset code to see if i can do a cycle run.
I pressed heavy wash 3 times and then start to make it perform a field test. It tested fine, but it stuck at 61 minutes for an hour while I was testing auto clean. Another thread indicated that the controller cable interface was getting moist.
Dec 05, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
My maytag MJD 2005 is getting partway through it's wash then tripping the house safety switch or circuit breaker
The most common problem that would make that happen is the motor going bad...
heatman101
Apr 30, 2011 | Maytag Dishwashers
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
Wont start..light wash lights up and delay wash lights up but start button wont work. replaced handle and it worked one time
There are two micro-switches just inside the handle mechanism that apply power when the door latches. You need to remove the interior panel to access. Hope this helps!
Jul 26, 2010 | Maytag Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Maytag mjd 2005 when started on normal gives a once-every-two-seconds "wash". Seems to pump out some water each time. When turned off and on again 'normal' button lights and the same thing happens. Will...
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Maytag 24 in. MDB9750AW Dishwasher
Will not start - Seems to be stuck on Half Load & Economy Cycle
Try to unplug the power cable for few houres and then plug it again. It mighet reset the control unit. Good luck !
Jul 22, 2007 | Zanussi 24 in. DE6744S Free-standing...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
