Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Wont turn on.
The green light flashes three times and then I have to wait one minute and it does it again. For a while it would turn on after two or three resets. Now nothing. What is wrong?
  • eduhler May 19, 2009
    TV wont turn on, when you press power it cycles three times and never turns on. Have to wait a couple minutes and try again. At first it would turn on after a couple trys now it wont turn on no matter how many times you try!
  • thachad108 May 21, 2009
    how do i check the power supply board
Slinteriors
  • 8617 Answers
SOURCE: RCA 65 inch HDTV TV
yes what your describing is possibly a flyback which is very inexspensive and easy to fix. But I will need the model number of your RCA to be positive and tell you which flyback you need. So please respond to this same post with the model number and I will provide the proper info so you can repair the set without alot of exspense.
Posted on Jul 04, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Mar 06, 2009
SOURCE: My RCA HD52W59 HDTV wont power on.
power supply switch is bad
Posted on Mar 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
Posted on Apr 16, 2010
Htc evo 4g turned off and wont turn back on and is flashing orange and green lights
That ussually means the battery is overheating! Take the battery out and wait 30 minute to put back in, but don't turn the phone on. Start charging it again, and if it continues to flash, take it to your provider IMEDIATLY!
Jul 14, 2013 | HTC Cell Phones
Green Light Flashes
Can you please post an image... That would be really helpful to see what you mean by gibberish
Mar 02, 2008 | HP DeskJet 930c InkJet Printer
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Ps3 problem : wont turn on
First Try these steps for basic troubleshooting, your PS3 has got "Yellow Light of Death" hardware fault
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
The problem you have encountered needs professional service and repair, so do not try fiddling much with your PS3 at home, if the above steps do not work please send your playstation 3 for repairs to Sony.
Wishing you Happy Holidays and Happy Gaming
Regards
KreativeGeek
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
My sony KP-57ws500 flashes green then turns off.
YOU HAVE A BAD GREEN CRT. UNIT IS NOT WORTH REPAIRING SINCE YOU WOULD HAVE TO REPLACE ALL 3 CRTS FOR THE UNIT TO SET UP PROPERLY.
Jan 12, 2009 | Sony KP-57WS500 57" Rear Projection...
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
