Question about Kitchen Appliances - Others
Foodsaver hose wont retract - Kitchen Appliances - Others
Foodsaver repair
Sorry to laugh, but that is too funny!
These retractable cords are very difficult to get back in order. You would be better off just closing up the sealer and allow the cord to remain extended. You could spend hours rewinding the cord and setting the tension spring when it pops open and makes you a crazy person.
Mar 12, 2014 | Kitchen Appliances - Others
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
Foodsaver wont vacuum v3230
Make sure you put the bag in as it's designed to go in, I s**t you not I tried to use a wider foodsaver bag and cut it down but I inserted it the opposite way than it was intended to go in and it would NOT vacuum the air out. So I cut another bag to test if inserting it the correct way would matter....and it TOTALLY worked fine! Crazy how I couldn't get it to work the other way.
Jun 30, 2012 | Kitchen Appliances - Others
I have a tilia foodsaver mdel # 204029 --don't have a owner manual and can figure out how to pull a vaccuum
The Quick Start Guide for the FoodSaver V420/Mini Plus is available here:
http://www.foodsaver.com/Manuals/MANUALS/FSMiniPlus_V420QuickStart_3_44.pdf
The guide had complete instructions on how to use.
You may wan to to browse the website so you are familar with other available resources:
http://www.foodsaver.com/Support.aspx
Apr 26, 2011 | Tilia FoodSaver VAC420
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Sep 04, 2010 | Microwave Ovens
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Telescope wont retract into hose
get a replacement hose witch is fairly hard to fit
Aug 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kitchen Appliances - Others Logo
225 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
