Question about Deadbolt Weiser Powerbolt 1000 Keyless Touchpad + Knob
Unlocking the door
When I unlock the door the latch doesn't go all the way into the door, leaving the latch sticking out a bit.
    New Friend:
Same issue. But I have Garrison instead.
Posted on Jan 18, 2014
Oven locked E1 F5 oven locked, how to unlock whirpool oven
try unplugging it and when you plug it back in hopefully it will open.the latch assy. is stuck,i don't know what model you have,if you look above the door through the grill slots can you see the latch assy. if so unplug the stove or flip the breaker with a screw driver see if you can move the latch or if you have a long skinny screw driver or anything that you can push on the latch with see if you can lift up on the latch to see if it will free up and when you plug it back in it will unlock,if you try to free the latch in the door and are not sticking anything through the slots you can leave the power on,you can try lifting up on the door or wiggle the door,all you're trying to do is get that latch to free up so it will move and don't self clean it again if you get it open,self cleaning can cause damage to the electronics on an oven and i would never use it.good luck
Nov 08, 2017 | Ovens
2000 toyota echo door
It depends on the actual problem. A body shop may be able to use a tool to go down thru the window sill to unlock the latch. If the latch is damaged, you may have to cut into the door to remove it.
Jul 01, 2013 | Cars & Trucks
1996 lincoln continental door latch does not lock/unlock door from inside or outide...door stays open basically...door latch has no response, unlock/lock switch works
I have the same problem.(Door will not stay closed) The door latch itself seems worn to the point where the linkage from both the actuator or door handle causes the latch to get stuck. I can free it with a screw driver applied where linkage connects to the latch, but it will stick again. Dealer wants over 300 with actuator. I am looking in junk yard for part. Remove door panel, somehow disconnect linkage from latch. It makes more sense to remove 3 hex or star screws 1st (27mm) so latch will be more accessible. My problem is the door latch, not anything else. Good luck
Jan 24, 2011 | 1996 Lincoln Continental
I had to replace the battery and now the Door not latched shows on dash and I can not lock with door lock switch, Radio does not cut off when opening the doors and the key remote will not unlock the doors...
pull the door panel on that door , where the door latches is a switch you will be able to see or feel the wire its a common prob sometimes gettin it out and in is a pain but its pretty straight forward
Jul 25, 2010 | 2002 Ford F250 Super Duty SuperCab
How to unlock a child proof lock for a Toyota Camry?
open the door (from the outside)
keep the door open, sit down on your heels and look at the inside of the door next to the latch, (the bit you never see with the door closed) you will see a little "tag" sticking out, probably with <LOCK/UNLOCK> printed next to it, this is the child-lock.
please leave feedback good or bad
Jan 21, 2010 | 2000 Renault 181
Drivers Door will not unlock. Inside or outside or with the key
Pull the inside panel off ,and look at the latch itself,that latches the door,and look for the lever that locks the latch,it will be sticking out of the latch,and try and release the lock by moving the lever.
Nov 09, 2009 | 1997 Jeep Wrangler
Passenger sliding door doesn´t unlock (Power locks). When pulling the handle either inside or outside with doors unlocked it won´t open.
Sound like you have a dammaged door latch assembly. It is a pain but you have to take the insid door trim panal off to see what you are doing and make sure the latch assy is un locking. Dis connect power door lock motor linkage to make sure motot is not jaming the lock in the lock possition.
Oct 07, 2009 | Ford Windstar Cars & Trucks
1999 gmc suburban, door lock won't unlock
You need your door lock actuator's replaced because they are sticking.
Apr 09, 2009 | 1999 GMC Suburban
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Deadbolt Weiser Powerbolt 1000 Keyless Touchpad  + Knob Logo
159 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Bill Boyd
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
