Question about Toshiba Satellite P105-S6177 Notebook
Pink vertical line
I have a pink vertical line that showed up on my Toshiba satellite laptop about 1 1/2 inches from the side. What can I do to fix this
    Problem Solver:
  • 10 Answers
From what you discribe it sounds like you have a row of dead pixels.
You can use this website to test for dead pixels:
http://www.gdargaud.net/Hack/DeadPixels.html
If you run the test and confirm that you have dead pixels, contact the laptop's manufacturer for support.
Posted on May 19, 2009
Toshiba satellite has pink screen .
Pink screen (with vertical lines) is due to faulty RAM. As far as my experience tells me, if you are having two RAM Chips, one of them could be the faulty one. RAM modules can be checked/replaced by opening the cover located underneath the laptop. If you have two RAM Modules, try using one at a time to identify the faulty one. Make sure you turn off the laptop, remover the adaptor cord and battery before removing and reinstalling RAM.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | Computers & Internet
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Pink and blue vertical lines through
It could just need the print heads cleaning or aligning
If you are not sure contact the shop you purchased your printer from it is under warrenty for 12 months
Apr 03, 2010 | Computers & Internet
I have vertical lines (15 of them now) on my Toshiba laptop.
I'm afraid when you see vertical line on an lcd panel, it most likely is screen failure. Ebay has plenty of screen from good companies in Texas. I get most of my screens from Ebay store LCDTECH99. They have the best prices, most screens are under 100 bucks and they ship right away. The Toshiba screen is an easy repair, Only the bezel needs to be removed in most cases. Below is a guide to show the process.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Nov 27, 2009 | Toshiba Satellite P105-S6227 Notebook
EXACTLY the same problem.
This is a common lcd issue. The pcb board in the lcd is defective (cracked or broken). The only way to fix it is to have the lcd replaced
Jul 10, 2009 | Toshiba Satellite P105-S6177 Notebook
Vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Apr 23, 2009 | Toshiba Satellite 2455-S305 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
I had to replace my Toshiba A105 screen recently due to damage. I installed the new screen myself and it worked fine for a while, but now it has a pink vertical line about an inch thick running down the...
Ok then, take it apart again and make sure all the connections are well seated, check the inverter (circuit board under the screen) the ribbon cable that goes behind the the screen and the block connector that attaches to the motherboard. If all theses connections are well seated and you still get the pink line, the screen is defective and you need to send it back.
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Toshiba Satellite A105-S4004 Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Toshiba Satellite P105-S6177 Notebook Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
